| | FTP acces problems with IE Trying to upload some files using IE which howewer proves a though task, alternatly im using a 3rd party program for it. But im sure thats not intended. The problem is i open a ftp site, and logon, It shows AS a HTML site, well i can browse the site and such and i can download. but i cannot add my files as i could on XP. How want it, is to open a ftp site AS a folder style. so i can drag/drop objects between the folders ![]() If IE7+ cant handle this, can someone advise/refer me to a browser with such abilities. Tx in advanced ![]() / Eqvaliser |
| Windows Vista™ Ultimate | IE7 does show ftpfiles in the old format, they changed the old behavior because of security concerns. just click on your view menu then click Open FTP Site in Windows Explorer or if you dont have the view menu click the "Page" button on the right then "open FTP Site in explorer" Hope it helps |
| | Re: FTP acces problems with IE Martin, IE 7 doesn't support FTP folder browsing. You have to use Explorer to accomplish this now. Open Windows Explore and enter the FTP site name in the address bar. This should give you the folder browsing again and allow you to upload files. OKuma "Martin Vaupell" <Eqvaliser@MSN.dk> wrote in message news:eU0w75umHHA.1244@TK2MSFTNGP04.phx.gbl... > > Trying to upload some files using IE which howewer proves a though task, > alternatly im using a 3rd party program for it. > But im sure thats not intended. > > The problem is i open a ftp site, and logon, > It shows AS a HTML site, well i can browse the site and such > and i can download. but i cannot add my files as i could on XP. > > How want it, is to open a ftp site AS a folder style. > so i can drag/drop objects between the folders ![]() > > If IE7+ cant handle this, can someone advise/refer me to a browser > with such abilities. > Tx in advanced ![]() > > / Eqvaliser |
| | Re: FTP acces problems with IE Ok any tips on how i do that,, back on windows xp, i would open my computer or any other folder and simply enter the ftp-url But when i do that here on vista, it pops up internet explore automatic and goes to requested ftp-url. So im haveing some troubles setting the settings for explore ? vs internet explore. Kind regards Martin V. "OKuma" <okuma@okumaware.com> skrev i meddelelsen news:F01DF04B-3A70-40DE-8647-52D8CFE5E128@microsoft.com... > Martin, > > IE 7 doesn't support FTP folder browsing. > > You have to use Explorer to accomplish this now. > > Open Windows Explore and enter the FTP site name in the address bar. > > This should give you the folder browsing again and allow you to upload > files. > > OKuma |
| | Re: FTP acces problems with IE Are you clicking on a link to an FTP site? If you are, it will open up IE If this happens, click on the 'Page' button and select 'Open FTP site in Windows Explorer' If this option is not available, click on Tools, Internet Options Click on Advanced Under Browsing, make sure Enable FTP folder view (Outside of Internet Explorer) is checked. OKuma "Martin Vaupell" <Eqvaliser@MSN.dk> wrote in message news:OhzTMVinHHA.4032@TK2MSFTNGP02.phx.gbl... > Ok any tips on how i do that,, back on windows xp, i would open > my computer or any other folder and simply enter the ftp-url > > But when i do that here on vista, it pops up internet explore automatic > and goes to requested ftp-url. > > So im haveing some troubles setting the settings for explore ? vs internet > explore. > > Kind regards > > Martin V. > > > "OKuma" <okuma@okumaware.com> skrev i meddelelsen > news:F01DF04B-3A70-40DE-8647-52D8CFE5E128@microsoft.com... >> Martin, >> >> IE 7 doesn't support FTP folder browsing. >> >> You have to use Explorer to accomplish this now. >> >> Open Windows Explore and enter the FTP site name in the address bar. >> >> This should give you the folder browsing again and allow you to upload >> files. >> >> OKuma > |
| | #6 (permalink) |
| | Re: FTP acces problems with IE It worked,, Ftp browsing is enabled again. and set up a few sites, as remote drives in "my computer" its awsome. Tx.. ![]() Good weekend ![]() Martin |
Acces problems | Microsoft Office | |||
| Cannot acces Vista from XP | Vista networking & sharing | |||
| Vista to XP acces problems!!! | Vista networking & sharing | |||
| Can't acces other computer | Vista networking & sharing | |||
| Acces to progs. | Vista installation & setup | |||
