Vista - ADSL Router problem (USR 9003)
Old 05-21-2007   #1 (permalink)
Paolo M.
I have an USRobotics 9003 ADSL ,
it let me browse the internet with Internet Explorer but not connect with
Windows Mail or Windows Live Messenger, or any other program like skype etc...
I testet my router with the online Internet Connectivity Evaluation Tool
and it says that my router is not UPnP enabled.
Is it possible that this caracteristic blocks my internet connections ?
(In my LAN any other operating system works fine, except for the latest
ubuntu 7.04 maybe for the same reason, because it has the same behaviour of
Vista)
Tnx
Old 05-22-2007   #2 (permalink)
Karl Froelich [MS]
Re: ADSL Router problem (USR 9003)
Computers use UPnP to create static port mappings on the router. I would
advise you to poke around on your router's web page, and find the place to
enable UPnP. Also, your firewall may be set to "no exceptions", this would
block you.
You should also be certain you have recent firmware for your device.
Can you post the detail report from running the IGDtool webpage?
Cheers,
k
"Paolo M." <PaoloM@discussions.microsoft.com> wrote in message
news:F811F47B-D229-42AB-94F0-79F7B93D1B87@microsoft.com...
> etc...
> of
> Vista)
> Tnx
Old 05-24-2007   #3 (permalink)
Paolo M.
Here is the report: i have the latest firmware but i suppose my router is not
"modern" and doesn't have UPnP, but it shouldn't be a problem for
applications :-(
I don't think it's a problem of the lack of UPnP capabilities of my router ...
Why XP should work and Vista not ?
IGDEvaluators
Version. 1.3.5.0 - Report
Test 1 - Basic Internet Connectivity Test Supported
Result:
Trying to construct an open request to the webpage :
/windows/using/tools/igd/StaticContent/igdprobedocs/connectivity/test.txt
Successfully constructed an open request
Trying to send the constructed open request
Successfully sent the constructed open request
Waiting for the response from the IGD test server
Successfully received the response from the test server
Querying the data size of the received content
Successfully queried the data size of the received content
Received 162 bytes of content from the IGD test server
IPv4 Connectivity succeeds through the Internet Gateway Device
Test 2 - Network Address Translator Type Supported
Result:
Trying to resolve the Teredo server IP address
Primary Teredo server IP address: 65.54.227.138
Secondary Terdeo server IP address: 65.54.227.139
Starting exercise with primary Teredo server
Sending a Router Solicitation frame with ConeBit on
Waiting for Router Advertisement
Sending a Router Solicitation frame with ConeBit off
Received a Router Advertisement frame
Starting exercise with secondary Teredo server
Waiting for Router Advertisement frame
The IGD's NAT type is RESTRICTED CONE
Test 3 - Traffic Congestion Test Supported
Result:
Trying to load library nsi.dll
ECN is disabled
Turning on ECN for testing
Trying to connect to the test server www.microsoft.com
Successfully connected to the test server
Fetching the webpage
/windows/using/tools/igd/StaticContent/igdprobedocs/ecn/test.txt from the
test server
Received 28 bytes of content from the test server
Restoring the original ECN settings
Turning off ECN
Test 4 - TCP High Performance Test Supported
Result:
The current Auto Tuning Level is set to Normal
Testing with webpage
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test13.txt of size 8192
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test13.txt from the
test server
Received 8192 bytes of content from the test server
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test14.txt of size
16384
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test14.txt from the
test server
Received 16384 bytes of content from the test server
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test16.txt of size
65536
/windows/using/tools/igd/StaticContent/igdprobedocs/ws/test16.txt from the
test server
Failed to get the webpage from the test server
Trying to test again
test server
16384
test server
65536
test server
Received 65536 bytes of content from the test server
Test 5 - UPnP Support Test Not supported
Result:
The operating system is Windows Vista
The firewall is disabled
UPnP is enabled by the firewall
UPnP services are running
UPnP Discovery is enabled
Detecting Internet Gateway Devices on the network
0 IGD(s) found
Failed to find any Internet Gateway Devices
Test 6 - Multiple Simultaneous Connection States Test Supported
Result:
This test attempts to sustain 80 concurrent TCP sessions
Opening TCP session test thread 0
Opening TCP session test thread 1
TCP Session test thread 0 is started
TCP Session test thread 0 is starting to exchange data with the test server
Opening TCP session test thread 2
Opening TCP session test thread 3
Opening TCP session test thread 4
TCP Session test thread 1 is started
Opening TCP session test thread 5
Opening TCP session test thread 6
Opening TCP session test thread 7
Opening TCP session test thread 8
Opening TCP session test thread 9
TCP Session test thread 2 is started
10 TCP session test threads are now running
Waiting for 10 seconds
TCP Session test thread 8 is started
TCP Session test thread 3 is started
TCP Session test thread 4 is started
TCP Session test thread 6 is started
TCP Session test thread 2 is starting to exchange data with the test server
TCP Session test thread 8 is starting to exchange data with the test server
TCP Session test thread 4 is starting to exchange data with the test server
TCP Session test thread 5 is started
TCP Session test thread 5 is starting to exchange data with the test server
TCP Session test thread 7 is started
TCP Session test thread 9 is started
TCP Session test thread 3 is starting to exchange data with the test server
TCP Session test thread 6 is starting to exchange data with the test server
TCP Session test thread 7 is starting to exchange data with the test server
TCP Session test thread 9 is starting to exchange data with the test server
TCP Session test thread 1 is starting to exchange data with the test server
Opening TCP session test thread 10
Opening TCP session test thread 11
TCP Session test thread 10 is started
Opening TCP session test thread 12
TCP Session test thread 10 is starting to exchange data with the test server
Opening TCP session test thread 13
Opening TCP session test thread 14
TCP Session test thread 11 is started
Opening TCP session test thread 15
TCP Session test thread 12 is started
Opening TCP session test thread 16
Opening TCP session test thread 17
TCP Session test thread 12 is starting to exchange data with the test server
Opening TCP session test thread 18
Opening TCP session test thread 19
20 TCP session test threads are now running
TCP Session test thread 16 is started
TCP Session test thread 13 is started
TCP Session test thread 16 is starting to exchange data with the test server
TCP Session test thread 15 is started
TCP Session test thread 15 is starting to exchange data with the test server
TCP Session test thread 18 is started
TCP Session test thread 13 is starting to exchange data with the test server
TCP Session test thread 18 is starting to exchange data with the test server
TCP Session test thread 14 is started
TCP Session test thread 17 is started
TCP Session test thread 14 is starting to exchange data with the test server
TCP Session test thread 17 is starting to exchange data with the test server
TCP Session test thread 19 is started
TCP Session test thread 19 is starting to exchange data with the test server
TCP Session test thread 11 is starting to exchange data with the test server
Opening TCP session test thread 20
Opening TCP session test thread 21
Opening TCP session test thread 22
Opening TCP session test thread 23
TCP Session test thread 20 is started
Opening TCP session test thread 24
Opening TCP session test thread 25
Opening TCP session test thread 26
Opening TCP session test thread 27
Opening TCP session test thread 28
Opening TCP session test thread 29
30 TCP session test threads are now running
TCP Session test thread 20 is starting to exchange data with the test server
TCP Session test thread 22 is started
TCP Session test thread 22 is starting to exchange data with the test server
TCP Session test thread 24 is started
TCP Session test thread 24 is starting to exchange data with the test server
TCP Session test thread 26 is started
TCP Session test thread 26 is starting to exchange data with the test server
TCP Session test thread 28 is started
TCP Session test thread 28 is starting to exchange data with the test server
TCP Session test thread 21 is started
TCP Session test thread 21 is starting to exchange data with the test server
TCP Session test thread 23 is started
TCP Session test thread 23 is starting to exchange data with the test server
TCP Session test thread 25 is started
TCP Session test thread 25 is starting to exchange data with the test server
TCP Session test thread 27 is started
TCP Session test thread 27 is starting to exchange data with the test server
TCP Session test thread 29 is started
TCP Session test thread 29 is starting to exchange data with the test server
Opening TCP session test thread 30
Opening TCP session test thread 31
Opening TCP session test thread 32
TCP Session test thread 30 is started
Opening TCP session test thread 33
Opening TCP session test thread 34
Opening TCP session test thread 35
Opening TCP session test thread 36
Opening TCP session test thread 37
Opening TCP session test thread 38
Opening TCP session test thread 39
40 TCP session test threads are now running
TCP Session test thread 30 is starting to exchange data with the test server
TCP Session test thread 32 is started
TCP Session test thread 32 is starting to exchange data with the test server
TCP Session test thread 34 is started
TCP Session test thread 34 is starting to exchange data with the test server
TCP Session test thread 36 is started
TCP Session test thread 36 is starting to exchange data with the test server
TCP Session test thread 38 is started
TCP Session test thread 38 is starting to exchange data with the test server
TCP Session test thread 31 is started
TCP Session test thread 31 is starting to exchange data with the test server
TCP Session test thread 33 is started
TCP Session test thread 33 is starting to exchange data with the test server
TCP Session test thread 35 is started
TCP Session test thread 35 is starting to exchange data with the test server
TCP Session test thread 37 is started
TCP Session test thread 37 is starting to exchange data with the test server
TCP Session test thread 39 is started
TCP Session test thread 39 is starting to exchange data with the test server
Opening TCP session test thread 40
Opening TCP session test thread 41
TCP Session test thread 40 is started
Opening TCP session test thread 42
TCP Session test thread 41 is started
TCP Session test thread 40 is starting to exchange data with the test server
TCP Session test thread 41 is starting to exchange data with the test server
Opening TCP session test thread 43
TCP Session test thread 42 is started
Opening TCP session test thread 44
TCP Session test thread 42 is starting to exchange data with the test server
Opening TCP session test thread 45
TCP Session test thread 43 is started
Opening TCP session test thread 46
TCP Session test thread 43 is starting to exchange data with the test server
Opening TCP session test thread 47
TCP Session test thread 44 is started
TCP Session test thread 45 is started
Opening TCP session test thread 48
Opening TCP session test thread 49
TCP Session test thread 45 is starting to exchange data with the test server
50 TCP session test threads are now running
TCP Session test thread 44 is starting to exchange data with the test server
TCP Session test thread 47 is started
TCP Session test thread 47 is starting to exchange data with the test server
TCP Session test thread 48 is started
TCP Session test thread 49 is started
TCP Session test thread 48 is starting to exchange data with the test server
TCP Session test thread 49 is starting to exchange data with the test server
TCP Session test thread 46 is started
TCP Session test thread 46 is starting to exchange data with the test server
Opening TCP session test thread 50
Opening TCP session test thread 51
TCP Session test thread 50 is started
Opening TCP session test thread 52
TCP Session test thread 51 is started
TCP Session test thread 50 is starting to exchange data with the test server
Opening TCP session test thread 53
TCP Session test thread 52 is started
Opening TCP session test thread 54
Opening TCP session test thread 55
Opening TCP session test thread 56
Opening TCP session test thread 57
Opening TCP session test thread 58
Opening TCP session test thread 59
60 TCP session test threads are now running
TCP Session test thread 52 is starting to exchange data with the test server
TCP Session test thread 54 is started
TCP Session test thread 54 is starting to exchange data with the test server
TCP Session test thread 56 is started
TCP Session test thread 56 is starting to exchange data with the test server
TCP Session test thread 58 is started
TCP Session test thread 58 is starting to exchange data with the test server
TCP Session test thread 51 is starting to exchange data with the test server
TCP Session test thread 53 is started
TCP Session test thread 55 is started
TCP Session test thread 53 is starting to exchange data with the test server
TCP Session test thread 55 is starting to exchange data with the test server
TCP Session test thread 57 is started
TCP Session test thread 59 is started
TCP Session test thread 57 is starting to exchange data with the test server
TCP Session test thread 59 is starting to exchange data with the test server
Opening TCP session test thread 60
Opening TCP session test thread 61
TCP Session test thread 60 is started
Opening TCP session test thread 62
TCP Session test thread 61 is started
Opening TCP session test thread 63
Opening TCP session test thread 64
TCP Session test thread 61 is starting to exchange data with the test server
Opening TCP session test thread 65
TCP Session test thread 60 is starting to exchange data with the test server
TCP Session test thread 63 is started
Opening TCP session test thread 66
TCP Session test thread 63 is starting to exchange data with the test server
Opening TCP session test thread 67
TCP Session test thread 65 is started
Opening TCP session test thread 68
Opening TCP session test thread 69
TCP Session test thread 65 is starting to exchange data with the test server
70 TCP session test threads are now running
TCP Session test thread 62 is started
TCP Session test thread 67 is started
TCP Session test thread 62 is starting to exchange data with the test server
TCP Session test thread 67 is starting to exchange data with the test server
TCP Session test thread 69 is started
TCP Session test thread 64 is started
TCP Session test thread 69 is starting to exchange data with the test server
TCP Session test thread 64 is starting to exchange data with the test server
TCP Session test thread 66 is started
TCP Session test thread 68 is started
TCP Session test thread 66 is starting to exchange data with the test server
TCP Session test thread 68 is starting to exchange data with the test server
Opening TCP session test thread 70
Opening TCP session test thread 71
TCP Session test thread 70 is started
Opening TCP session test thread 72
TCP Session test thread 71 is started
Opening TCP session test thread 73
TCP Session test thread 70 is starting to exchange data with the test server
Opening TCP session test thread 74
TCP Session test thread 71 is starting to exchange data with the test server
Opening TCP session test thread 75
TCP Session test thread 73 is started
Opening TCP session test thread 76
TCP Session test thread 73 is starting to exchange data with the test server
Opening TCP session test thread 77
TCP Session test thread 72 is started
Opening TCP session test thread 78
TCP Session test thread 74 is started
TCP Session test thread 72 is starting to exchange data with the test server
Opening TCP session test thread 79
TCP Session test thread 76 is started
80 TCP session test threads are now running
TCP Session test thread 74 is starting to exchange data with the test server
TCP Session test thread 75 is started
TCP Session test thread 75 is starting to exchange data with the test server
TCP Session test thread 78 is started
TCP Session test thread 77 is started
TCP Session test thread 76 is starting to exchange data with the test server
TCP Session test thread 77 is starting to exchange data with the test server
TCP Session test thread 79 is started
TCP Session test thread 78 is starting to exchange data with the test server
TCP Session test thread 79 is starting to exchange data with the test server
Waiting for TCP session 0 to exit
TCP Session test thread 55 is exiting
TCP Session test thread 19 is exiting
TCP Session test thread 53 is exiting
TCP Session test thread 4 is exiting
TCP Session test thread 29 is exiting
TCP Session test thread 39 is exiting
TCP Session test thread 42 is exiting
TCP Session test thread 54 is exiting
TCP Session test thread 7 is exiting
TCP Session test thread 34 is exiting
TCP Session test thread 2 is exiting
TCP Session test thread 28 is exiting
TCP Session test thread 30 is exiting
TCP Session test thread 24 is exiting
TCP Session test thread 63 is exiting
TCP Session test thread 66 is exiting
TCP Session test thread 68 is exiting
TCP Session test thread 35 is exiting
TCP Session test thread 57 is exiting
TCP Session test thread 23 is exiting
TCP Session test thread 18 is exiting
TCP Session test thread 64 is exiting
TCP Session test thread 26 is exiting
TCP Session test thread 76 is exiting
TCP Session test thread 70 is exiting
TCP Session test thread 27 is exiting
TCP Session test thread 71 is exiting
TCP Session test thread 5 is exiting
TCP Session test thread 73 is exiting
TCP Session test thread 74 is exiting
TCP Session test thread 61 is exiting
TCP Session test thread 75 is exiting
TCP Session test thread 79 is exiting
TCP Session test thread 46 is exiting
TCP Session test thread 12 is exiting
TCP Session test thread 6 is exiting
TCP Session test thread 59 is exiting
TCP Session test thread 17 is exiting
TCP Session test thread 40 is exiting
TCP Session test thread 25 is exiting
TCP Session test thread 48 is exiting
TCP Session test thread 45 is exiting
TCP Session test thread 43 is exiting
TCP Session test thread 77 is exiting
TCP Session test thread 69 is exiting
TCP Session test thread 78 is exiting
TCP Session test thread 9 is exiting
TCP Session test thread 52 is exiting
TCP Session test thread 49 is exiting
TCP Session test thread 36 is exiting
TCP Session test thread 3 is exiting
TCP Session test thread 33 is exiting
TCP Session test thread 8 is exiting
TCP Session test thread 15 is exiting
TCP Session test thread 10 is exiting
TCP Session test thread 37 is exiting
TCP Session test thread 62 is exiting
TCP Session test thread 44 is exiting
TCP Session test thread 1 is exiting
TCP Session test thread 38 is exiting
TCP Session test thread 16 is exiting
TCP Session test thread 56 is exiting
TCP Session test thread 60 is exiting
TCP Session test thread 11 is exiting
TCP Session test thread 31 is exiting
TCP Session test thread 47 is exiting
TCP Session test thread 50 is exiting
TCP Session test thread 65 is exiting
TCP Session test thread 0 is exiting
TCP session 0 has exited
Waiting for TCP session 1 to exit
TCP session 1 has exited
Waiting for TCP session 2 to exit
TCP session 2 has exited
Waiting for TCP session 3 to exit
TCP session 3 has exited
Waiting for TCP session 4 to exit
TCP session 4 has exited
Waiting for TCP session 5 to exit
TCP session 5 has exited
Waiting for TCP session 6 to exit
TCP session 6 has exited
Waiting for TCP session 7 to exit
TCP session 7 has exited
Waiting for TCP session 8 to exit
TCP session 8 has exited
Waiting for TCP session 9 to exit
TCP session 9 has exited
Waiting for TCP session 10 to exit
TCP session 10 has exited
Waiting for TCP session 11 to exit
TCP session 11 has exited
Waiting for TCP session 12 to exit
TCP session 12 has exited
Waiting for TCP session 13 to exit
TCP Session test thread 67 is exiting
TCP Session test thread 20 is exiting
TCP Session test thread 14 is exiting
TCP Session test thread 51 is exiting
TCP Session test thread 21 is exiting
TCP Session test thread 22 is exiting
TCP Session test thread 41 is exiting
TCP Session test thread 58 is exiting
TCP Session test thread 72 is exiting
TCP Session test thread 32 is exiting
TCP Session test thread 13 is exiting
TCP session 13 has exited
Waiting for TCP session 14 to exit
TCP session 14 has exited
Waiting for TCP session 15 to exit
TCP session 15 has exited
Waiting for TCP session 16 to exit
TCP session 16 has exited
Waiting for TCP session 17 to exit
TCP session 17 has exited
Waiting for TCP session 18 to exit
TCP session 18 has exited
Waiting for TCP session 19 to exit
TCP session 19 has exited
Waiting for TCP session 20 to exit
TCP session 20 has exited
Waiting for TCP session 21 to exit
TCP session 21 has exited
Waiting for TCP session 22 to exit
TCP session 22 has exited
Waiting for TCP session 23 to exit
TCP session 23 has exited
Waiting for TCP session 24 to exit
TCP session 24 has exited
Waiting for TCP session 25 to exit
TCP session 25 has exited
Waiting for TCP session 26 to exit
TCP session 26 has exited
Waiting for TCP session 27 to exit
TCP session 27 has exited
Waiting for TCP session 28 to exit
TCP session 28 has exited
Waiting for TCP session 29 to exit
TCP session 29 has exited
Waiting for TCP session 30 to exit
TCP session 30 has exited
Waiting for TCP session 31 to exit
TCP session 31 has exited
Waiting for TCP session 32 to exit
TCP session 32 has exited
Waiting for TCP session 33 to exit
TCP session 33 has exited
Waiting for TCP session 34 to exit
TCP session 34 has exited
Waiting for TCP session 35 to exit
TCP session 35 has exited
Waiting for TCP session 36 to exit
TCP session 36 has exited
Waiting for TCP session 37 to exit
TCP session 37 has exited
Waiting for TCP session 38 to exit
TCP session 38 has exited
Waiting for TCP session 39 to exit
TCP session 39 has exited
Waiting for TCP session 40 to exit
TCP session 40 has exited
Waiting for TCP session 41 to exit
TCP session 41 has exited
Waiting for TCP session 42 to exit
TCP session 42 has exited
Waiting for TCP session 43 to exit
TCP session 43 has exited
Waiting for TCP session 44 to exit
TCP session 44 has exited
Waiting for TCP session 45 to exit
TCP session 45 has exited
Waiting for TCP session 46 to exit
TCP session 46 has exited
Waiting for TCP session 47 to exit
TCP session 47 has exited
Waiting for TCP session 48 to exit
TCP session 48 has exited
Waiting for TCP session 49 to exit
TCP session 49 has exited
Waiting for TCP session 50 to exit
TCP session 50 has exited
Waiting for TCP session 51 to exit
TCP session 51 has exited
Waiting for TCP session 52 to exit
TCP session 52 has exited
Waiting for TCP session 53 to exit
TCP session 53 has exited
Waiting for TCP session 54 to exit
TCP session 54 has exited
Waiting for TCP session 55 to exit
TCP session 55 has exited
Waiting for TCP session 56 to exit
TCP session 56 has exited
Waiting for TCP session 57 to exit
TCP session 57 has exited
Waiting for TCP session 58 to exit
TCP session 58 has exited
Waiting for TCP session 59 to exit
TCP session 59 has exited
Waiting for TCP session 60 to exit
TCP session 60 has exited
Waiting for TCP session 61 to exit
TCP session 61 has exited
Waiting for TCP session 62 to exit
TCP session 62 has exited
Waiting for TCP session 63 to exit
TCP session 63 has exited
Waiting for TCP session 64 to exit
TCP session 64 has exited
Waiting for TCP session 65 to exit
TCP session 65 has exited
Waiting for TCP session 66 to exit
TCP session 66 has exited
Waiting for TCP session 67 to exit
TCP session 67 has exited
Waiting for TCP session 68 to exit
TCP session 68 has exited
Waiting for TCP session 69 to exit
TCP session 69 has exited
Waiting for TCP session 70 to exit
TCP session 70 has exited
Waiting for TCP session 71 to exit
TCP session 71 has exited
Waiting for TCP session 72 to exit
TCP session 72 has exited
Waiting for TCP session 73 to exit
TCP session 73 has exited
Waiting for TCP session 74 to exit
TCP session 74 has exited
Waiting for TCP session 75 to exit
TCP session 75 has exited
Waiting for TCP session 76 to exit
TCP session 76 has exited
Waiting for TCP session 77 to exit
TCP session 77 has exited
Waiting for TCP session 78 to exit
TCP session 78 has exited
Waiting for TCP session 79 to exit
TCP session 79 has exited
The Internet Gateway Device sustains 80 concurrent TCP sessions
> block you.
> Cheers,
> k
> > etc...
> > of
> > Vista)
> > Tnx
Old 05-24-2007   #4 (permalink)
Gary VanderMolen
It is highly unlikely that your issue has anything to do with UPnP.
What you might try is turning off Vista's TCP autotuning.
There is a new TCP tuning feature in Vista which is
not compatible with some servers.
a. Go to the Vista start menu and type cmd
b. The search results will display a program named "cmd"
c. Right-click on the link and select "Run as administrator"
d. type "netsh interface tcp set global autotuning=disabled" without
the quotation marks
e. Test your POP email account and see if you can now download your mail.
f. If nothing changes, re-enable the autotuning feature by typing
"netsh interface tcp set global autotuning=normal"
Please post back with the results.
Gary VanderMolen
"Paolo M." <PaoloM@discussions.microsoft.com> wrote in message news:0E31EA7E-2901-496E-BB90-4B89BCEF82AC@microsoft.com...
> applications :-(
Old 05-28-2007   #5 (permalink)
Paolo M.
Gary VanderMolen you are my HERO....
Now all programs go through the firewall.....
even MSN Messanger, Skype etc......
Could you explain me something more about this VISTA TCP tuning feature ?
Why only USR 9003 is affected...well i think only me, because the US Robotics
helpdesk doesn't know anything about this problem ??
I think Ubuntu 7.04 has a similar feature because has the same problem....
Anyway THANK YOU THANK YOU THANK YOU
i don't have to waste moneys for a new router..
Paolo Mazzoni
> the quotation marks
> Gary VanderMolen
> > applications :-(
Belkin N1 ADSL Router... Network & Sharing
My Desktop Connects To My ADSL Router But My Notebook Can't See It? Vista networking & sharing
Vista + adsl router (dlink) Vista networking & sharing
cant' accessto the adsl router Vista networking & sharing
BT Voyager 220V ADSL Voice Router Vista networking & sharing
