Vista - Wireless Connection
Old 05-28-2007   #1 (permalink)
SCrazygurl
Wireless Connection
I have a new laptop with Vista. My home network is a Linksys Wireless Router
on a WEP encryption. My other laptop running on XP can connect to the
router. The Vista laptop has been configured to the wireless network and
shows that the laptop is connected. However, no data can transmit. IE
displays an error message that the webpage cannot be displayed.
Old 05-28-2007   #2 (permalink)
SCrazygurl
RE: Wireless Connection
I forgot to mention that when I disable the security settings on the router,
the vista laptop can connect to the network. However, when I enable the
security settings, the laptop cannot transmit data.
Old 05-28-2007   #3 (permalink)
Windows Vista™ Ultimate
Check http://www.vistax64.com for guides on how to change the DHCP broadcast flag to the same as xp and the same as your router uses.
Old 05-28-2007   #4 (permalink)
Barb Bowman
Re: Wireless Connection
1. which Linksys router (model #/hardware rev)?
2. what firmware? if not the latest, please upgrade
3. is the SSID being broadcast?
You really should be using WPA2 or WPA since WEP is so unsafe these
days.
On Mon, 28 May 2007 02:00:01 -0700, SCrazygurl
Barb Bowman
MS Windows-MVP
Expert Zone & Vista Community Columnist
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
Old 05-28-2007   #5 (permalink)
SCrazygurl
The router is a N - wrt150N. it is the latest firmware - 1.1.2. Yes, the
SSID is being broadcast.
I'm not sure how to change to WPA. I don't think I have that option, I see
PSK in the drop down field.
> days.
> Barb Bowman
> MS Windows-MVP
Old 05-28-2007   #6 (permalink)
Barb Bowman
WPA-PSK is fine.
does this computer get an IP from the router or not? if yes, can you
open a cmd prompt and type
tracert yahoo.com [enter]
does it resolve?
On Mon, 28 May 2007 09:41:06 -0700, SCrazygurl
>> days.
>> Barb Bowman
>> MS Windows-MVP
Barb Bowman
MS Windows-MVP
Old 05-28-2007   #7 (permalink)
SCrazygurl
The Vista laptop cannot ping the router nor does using the cmd "tracert" have
any results. I took your earlier advice and changed the WEP to WPA-PSK
security type. The Vista laptop immediately connected and my XP laptop
immediately disconnected.
I had to reconfigure the XP laptop by deleting the network and reinstalling
the network to accept the new security protocols.
Thanks.
> WPA-PSK is fine.
> does it resolve?
> >> days.
> >> Barb Bowman
> >> MS Windows-MVP
> Barb Bowman
> MS Windows-MVP
Old 05-28-2007   #8 (permalink)
Barb Bowman
so both are now connected and working?
On Mon, 28 May 2007 12:21:00 -0700, SCrazygurl
>Thanks.
>> WPA-PSK is fine.
>> does it resolve?
>> >> days.
>> >> Barb Bowman
>> >> MS Windows-MVP
>> Barb Bowman
>> MS Windows-MVP
Barb Bowman
MS Windows-MVP
Old 05-28-2007   #9 (permalink)
...winston
All that was necessary was to change the XP encryption and passkey in the XP adapter's wireless settings to agree with that on the reconfigured router.
..winston
"SCrazygurl" <SCrazygurl@discussions.microsoft.com> wrote in message news:9E57F81C-745F-4A87-A5C6-F47AC8E4BFCD@microsoft.com...
: The Vista laptop cannot ping the router nor does using the cmd "tracert" have
: any results. I took your earlier advice and changed the WEP to WPA-PSK
: security type. The Vista laptop immediately connected and my XP laptop
: immediately disconnected.
: I had to reconfigure the XP laptop by deleting the network and reinstalling
: the network to accept the new security protocols.
: Thanks.
: "Barb Bowman" wrote:
: > WPA-PSK is fine.
: > does this computer get an IP from the router or not? if yes, can you
: > open a cmd prompt and type
: > tracert yahoo.com [enter]
: > does it resolve?
: > On Mon, 28 May 2007 09:41:06 -0700, SCrazygurl
: > <SCrazygurl@discussions.microsoft.com> wrote:
: > >The router is a N - wrt150N. it is the latest firmware - 1.1.2. Yes, the
: > >SSID is being broadcast.
: > >I'm not sure how to change to WPA. I don't think I have that option, I see
: > >PSK in the drop down field.
: > >"Barb Bowman" wrote:
: > >> 1. which Linksys router (model #/hardware rev)?
: > >> 2. what firmware? if not the latest, please upgrade
: > >> 3. is the SSID being broadcast?
: > >> You really should be using WPA2 or WPA since WEP is so unsafe these
: > >> days.
: > >> On Mon, 28 May 2007 02:00:01 -0700, SCrazygurl
: > >> <SCrazygurl@discussions.microsoft.com> wrote:
: > >> >I have a new laptop with Vista. My home network is a Linksys Wireless Router
: > >> >on a WEP encryption. My other laptop running on XP can connect to the
: > >> >router. The Vista laptop has been configured to the wireless network and
: > >> >shows that the laptop is connected. However, no data can transmit. IE
: > >> >displays an error message that the webpage cannot be displayed.
: > >> Barb Bowman
: > >> MS Windows-MVP
: > >> Expert Zone & Vista Community Columnist
: > >> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
: > >> http://blogs.digitalmediaphile.com/barb/
: > Barb Bowman
: > MS Windows-MVP
: > Expert Zone & Vista Community Columnist
: > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
: > http://blogs.digitalmediaphile.com/barb/
Cannot find wireless networks/Cannot enable wireless connection Network & Sharing
Wireless connection works, cable connection does not! Vista General
Unable to keep wireless connection on two USB wireless cards Network & Sharing
Losing wireless connection to specific wireless network Vista networking & sharing
Blackberry Dialup connection interupts wireless connection Vista networking & sharing
