Thanks Barb...
Until drivers are available or not at all..the op should be able to find a pci nic using the link.
And as you've implied there are nic's in existence that might not be featured on the site but do 'work' in Vista(e.g. my D-Link DWL-G630 laptop card worked from the get go..the only thing I needed to do was set the workgroup name, view available, connect and enter the WPA2/PSK key.
..winston
"Barb Bowman" <barb@nospam.com> wrote in message news:0rqv531t5mf49jqqajqp5vskes1f5ecfa6@4ax.com...
: some NICS night be covered by generic Broadcom or Atheros drivers as
: opposed to the vendors. However as I recall the WG311 V2 uses a
: Texas Instruments chipset and as far as I can tell, there are many
: unhappy folks still looking for a Vista driver.
: On Fri, 1 Jun 2007 01:43:59 -0400, "...winston" <merlin@druid9#.com>
: wrote:
: >Note the list only shows 3 NetGear Products
: Barb Bowman
: MS Windows-MVP
: Expert Zone & Vista Community Columnist
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
