Strange XP to Vista Authentication Problem
  1. #1
    David Dickinson Guest
    Hello,
    My problem is on a peer-to-peer network involving XP Pro and Vista Business.
    Identical user accounts are on all machines. I've applied the KB922120
    patch to XP. The Vista machine has sharing enabled, password required. I
    can access the Vista Machine via Remote Desktop from the XP machine.
    I want to share some folders on the Vista machine with the XP machine and
    only with specific users. I right-click a folder ("Test") that I want to
    share and select the Sharing tab. The Share button is disabled, so I use
    the Advanced Sharing button and add the Administrators group, giving it full
    control. I log on to the XP machine as an administrator that exists on the
    Vista machine.
    The Vista machine can see and access shares on the XP machine. The XP
    machine can /see/ all shares on the Vista machine, but can only /access/ the
    Public folders. I get an Access Denied error when I try to open the "Test"
    folder.
    However, if I add the Everyone group to the "Test" shared folder on Vista,
    then I can access the folder from XP.
    Why is this and how can I share only with the correct specific users rather
    than with Everyone?
    David Dickinson
    eveningstar at die-spammer-die dash mvps dot org
  2. #2
    Jimmy Brush Guest
    Re: Strange XP to Vista Authentication Problem
    Hello,
    This is caused by Windows Vista ignoring your membership in the local
    "Administrators" group when accessing it remotely (not through remote
    desktop).
    To get this to work correctly with your administrator group membership,
    you need to change this key on your vista box:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\system\
    Create a DWORD Value called: LocalAccountTokenFilterPolicy
    With the value: 1
    -JB
    Microsoft MVP - Windows Shell/User
    Windows Vista Support FAQ - http://www.jimmah.com/vista/
  3. #3
    Thanks, Jimmy! It worked!
    I wish I'd found your web site while searching for this solution. Great
    site!
    David Dickinson
    "Jimmy Brush" wrote in message
    news:ObwwUs%23pHHA.4632@TK2MSFTNGP04.phx.gbl...
Strange XP to Vista Authentication Problem problems?
General authentication problem windows authentication as SQLauthentication Dawid Kolodziejczyk Server General 0 01 Sep 2009
Vista Start Problem (Bit Strange) shr2004 General Discussion 4 01 Oct 2008
Really strange Vista problem Espen Vista General 0 01 Jan 2008
Vista clients and EAP-TLS authentication - problem with certificates Dr Zoidberg Vista security 5 19 Sep 2007
Vista RTM Network Authentication and VPN problem Jim Thorne Vista networking & sharing 0 07 Dec 2006
