| Guest | Strange permission problems when accessing SBS 2003 network share I've got some very strange permission problems on a Vista Laptop. In fact 2 Laptops, both with a fresh Vista install. The laptops are the only Vista machines in the network, and the only machines experiencing this problem.. It boils down to the fact that I can do some things which require read/write/execute permissions, while other things don't work. I really don't have a clue what else I can try, so hopefully someone is able to help me. This is the environment: - Vista Business on a Laptop, integrated in a Domain with Windows Small Business Server 2003 - All available updates are installed on the client and server. - Client is logged on with a Domain User account that is in the Local Administrators Group. Here are some of the things I am able to do on the network share: - I can see all files and directories. - I can copy a file to the network share. - I can open text files, change and save them. - I can open PDF files in Adobe Reader. - I can create a new document in Word and save it. And here are the things where I have permission problems: - I cannot open a Word document (I also tried other Office formats). The error message says "Permission denied. Please contact administrator" (translated from German, may not be accurate) - I cannot make a copy of a file on the network share - Permission denied. - I cannot copy a file from a network share to another one - Permission denied. Of course I have checked all the obvious things (and also some not so obvious ones) like: - Share permissions are set correctly. - NTFS permissions are set correctly. - 3rd party virus software is removed from the laptop. - UAC and Windows Defender are disabled. - All accounts on the client and server have passwords. I even tried to change the LAN Manager authentication level on the client. I also tried logging in with the Domain Admin account on the client, but the problems are the same. Any ideas? |
| Guest | Re: Strange permission problems when accessing SBS 2003 network share On Jun 12, 6:00 am, Martin Ennemoser <MartinEnnemo...@discussions.microsoft.com> wrote: > I've got some very strange permission problems on aVistaLaptop. In fact 2 > Laptops, both with a freshVistainstall. The laptops are the onlyVista > machines in the network, and the only machines experiencing thisproblem.. It > boils down to the fact that I can do some things which require > read/write/execute permissions, while other things don't work. I really don't > have a clue what else I can try, so hopefully someone is able to help me. > > This is the environment: > > -VistaBusiness on a Laptop, integrated in a Domain with Windows Small > BusinessServer2003 > - All available updates are installed on the client andserver. > - Client is logged on with a Domain User account that is in the Local > Administrators Group. > > Here are some of the things I am able to do on the networkshare: > > - I can see all files and directories. > - I can copy a file to the networkshare. > - I can open text files, change and save them. > - I can open PDF files in Adobe Reader. > - I can create a new document in Word and save it. > > And here are the things where I have permission problems: > > - I cannot open a Word document (I also tried otherOfficeformats). The > error message says "Permission denied. Please contact administrator" > (translated from German, may not be accurate) > - I cannot make a copy of a file on the networkshare- Permission denied. > - I cannot copy a file from a networkshareto another one - Permission > denied. > > Of course I have checked all the obvious things (and also some not so > obvious ones) like: > > -Sharepermissions are set correctly. > - NTFS permissions are set correctly. > - 3rd party virus software is removed from the laptop. > - UAC and Windows Defender are disabled. > - All accounts on the client andserverhave passwords. > > I even tried to change the LAN Manager authentication level on the client. I > also tried logging in with the Domain Admin account on the client, but the > problems are the same. > > Any ideas? Have a look at this discussion which sounds a bit similar. Vista/Office 2k3 "Access Denied" in Documents Folder http://www.tek-tips.com/viewthread.c...1379408&page=1 |
| Guest | Re: Strange permission problems when accessing SBS 2003 network sh Thanks for the tip, but I solved the problem in the meantime. As soon as I removed Kaspersky Antivirus from all servers and the Vista clients it worked. Only removing Kaspersky from the client was not enough. "mikelinstead@hotmail.com" wrote: > On Jun 12, 6:00 am, Martin Ennemoser > <MartinEnnemo...@discussions.microsoft.com> wrote: > > I've got some very strange permission problems on aVistaLaptop. In fact 2 > > Laptops, both with a freshVistainstall. The laptops are the onlyVista > > machines in the network, and the only machines experiencing thisproblem.. It > > boils down to the fact that I can do some things which require > > read/write/execute permissions, while other things don't work. I really don't > > have a clue what else I can try, so hopefully someone is able to help me. > > > > This is the environment: > > > > -VistaBusiness on a Laptop, integrated in a Domain with Windows Small > > BusinessServer2003 > > - All available updates are installed on the client andserver. > > - Client is logged on with a Domain User account that is in the Local > > Administrators Group. > > > > Here are some of the things I am able to do on the networkshare: > > > > - I can see all files and directories. > > - I can copy a file to the networkshare. > > - I can open text files, change and save them. > > - I can open PDF files in Adobe Reader. > > - I can create a new document in Word and save it. > > > > And here are the things where I have permission problems: > > > > - I cannot open a Word document (I also tried otherOfficeformats). The > > error message says "Permission denied. Please contact administrator" > > (translated from German, may not be accurate) > > - I cannot make a copy of a file on the networkshare- Permission denied. > > - I cannot copy a file from a networkshareto another one - Permission > > denied. > > > > Of course I have checked all the obvious things (and also some not so > > obvious ones) like: > > > > -Sharepermissions are set correctly. > > - NTFS permissions are set correctly. > > - 3rd party virus software is removed from the laptop. > > - UAC and Windows Defender are disabled. > > - All accounts on the client andserverhave passwords. > > > > I even tried to change the LAN Manager authentication level on the client. I > > also tried logging in with the Domain Admin account on the client, but the > > problems are the same. > > > > Any ideas? > > Have a look at this discussion which sounds a bit similar. > > Vista/Office 2k3 "Access Denied" in Documents Folder > http://www.tek-tips.com/viewthread.c...1379408&page=1 > > |
| Accessing Deault Admin Share | Network & Sharing | |||
| Vista Network share problems | Network & Sharing | |||
| Network share problems | Vista General | |||
| 2003 Network Share Painfully Slow | Vista networking & sharing | |||
| Accessing files on Vista network share breaks network | Vista networking & sharing | |||
