Hello,
Try using the 'Internet Connectivity Evaluation Tool' from Microsoft
http://www.microsoft.com/windows/usi...d/default.mspx) and see if
everything goes fine. Otherwise, you might have to change the settings for
your wireless card (which might be the culprit) through device manager
(Start > Search for Device Manger > Network Adaptors > Double click on your
wireless card's entry). Then make sure that the configuration is set just as
it is in XP and also make sure that the Wireless Network Connection
Properties (Control Panel > Network and Sharing Center > Manage Network
Connections > right click on your wireless network and click properties)
show that all the necessary protocols are installed.
Rishi
email:rishi@vista-news.com | web:
http://vista-news.com
"TobiLei" <TobiLei@discussions.microsoft.com> wrote in message
news:2232CE91-81D0-4A62-96A9-D1DB4FE87C51@microsoft.com...
> Hi,
> i have the same problem since 07-12-2007.
> Any connection via WLAN isn't active.
> Can any person help us ?
> TobiLei
> "Raniero" wrote:
>> Hello I am dualbooting XP and Vista, writing from XP I have installed
>> vista
>> ultimate but I am experiencing some wireless network problems, I have a
>> wireless router Wl-534, and a Wlan that came with the pc, it detected the
>> devices and the wireless networks, But the one that I use to connect to
>> the
>> internetis marked with an X and says that the PC doesnt meet the network
>> requirements, the same network works perfectly with XP, Thanks for all
>> your
>> help.
>> Raniero
