Vista - Please confirm: using an XP USB printer over LAN
Old 06-16-2007   #1 (permalink)
Qu0ll
Just to be sure, I would like someone to verify that if I have a
Vista-compatible printer connected to a USB port of an XP machine then I can
print to it from a Vista machine connected to the same domain if that
printer is shared on the XP machine and the drivers are installed on the
Vista machine.
Is this definitely correct?
And loving it,
-Q
_________________________________________________
Qu0llSixFour@gmail.com
(Replace the "SixFour" with numbers to email me)
Old 06-16-2007   #2 (permalink)
Kerry Brown
Re: Please confirm: using an XP USB printer over LAN
"Qu0ll" <Qu0llSixFour@gmail.com> wrote in message
news:uhYq%23v%23rHHA.4888@TK2MSFTNGP03.phx.gbl...
> can print to it from a Vista machine connected to the same domain if that
> Vista machine.
It depends on the printer driver. Not all USB printers will work over a
network. Some expect direct two way communications. You would have to
contact the printer manufacturer to see if yours will work when networked.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
How to Confirm BitLocker is off Vista security
Request to confirm Server Vista mail
Confirm-promt in PS-script PowerShell
Vista RTM 13. november? Does someone have a confirm? Vista General
Confirm use of Ghost on Vista Vista General
