only 1 way connection between vista and xp machine?
  1. #1
    acastruc Guest
    I recently bought a laptop running Vista. My desktop is running XP. Both are
    connected to the internet ok, through a linksys wireless router (well XP uses
    cable, laptop uses wireless). I enabled file/printer sharing on the xp and
    laptop and shared a folder on each. On the XP box I can see the vista laptop
    machine and access the shared folder no problem using a user name + password.
    However on the vista laptop I am unable to see the xp machine or view it's
    shared folder.
    Firewalls are turned off + workgroup names are the same.
    I checked the router, it assigns IPs:
    XP machine: x.x.x.101
    Vista laptop: x.x.x.102
    From XP I can ping x.102. From Vista if I try and ping the XP box I get the
    "connection timed out".
    Any help would be most appreciated.
  2. #2
    acastruc Guest
    RE: only 1 way connection between vista and xp machine?
    After doing a bit more searching I figured out what the problem was - I
    needed to install the LLTD upgrade on the XP box and it is working now.
    > shared folder.
  3. #3
    robbani Guest
    What is LLTD??? I too cannot see from xbox to my laptop thinking it was my
    router firewall could it be that ,I am pretty sure I ran all updates for xbox
    but LLTD I'm not sure ???
    > > shared folder.
  4. #4
    Robert L \(MS-MVP\) Guest
    Re: only 1 way connection between vista and xp machine?
    You need download LLTD from the MS. This post may help.
    Info: Vista can't see XP on ...After installing the LLTD Responder component
    on the XP machine, one vista pc could see the shared folders on the xp
    machine and the xp machine could see ...
    http://www.chicagotech.net/netforums...opic.php?t=236
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "robbani" <robbani@xxxxxx> wrote in message
    news:A60AFCCA-E6B4-4175-BEA7-5B6A069B15FC@xxxxxx
    > xbox
    >> > Both are
    >> > XP uses
    >> > and
    >> > laptop
    >> > password.
    >> > it's
    >> > shared folder.
    >> > the
only 1 way connection between vista and xp machine? problems?
Network connection from virtual machine PeterT Virtual PC 10 01 Jun 2009
XP machine drops network connection to Vista machine msnews.microsoft.com Vista networking & sharing 4 25 Feb 2009
Mapped drives on XP machine loosing connection with Vista PC Hyacinth Vista networking & sharing 1 19 Jan 2008
Remote Desktop connection to a Vista Basic Home machine AK_Paul Vista account administration 2 20 Jul 2007
Vista losing connection to XP machine Rob O. Vista networking & sharing 0 28 Feb 2007
