Vista Tutorial - Vista networking problem
Old 06-24-2007   #1 (permalink)
NB222
Guest
I have a vista laptop that is wireless and an xp desktop that is wired to my
linksys router.
when both computers were xp I was able to wirelessly print and file share.
Now that I upgraded the laptop to Vista I am only able to recieve the
internet connection wirelessly on the laptop, also I am able to share an
iTunes Library between both computers. The xp desktop does show up in the
Vista network map but I cannot connect to it or share files or the printers
that are plugged into it. I have installed the LLTD on the xp computer and I
have checked the firewalls.
I have asked a lot of people about this and I am hoping to come up with
an answer from someone. I'm not sure if this is just Vista sucking or if
there is a solution.
Someone please reply
Thanks,
Old 06-24-2007   #2 (permalink)
Chuck
Guest
Re: Vista networking problem
>linksys router.
>Thanks,
Check the NetBT setting on each computer - make sure it's Enabled.
<http://nitecruzr.blogspot.com/2006/07/advanced-windows-networking-using.html>
http://nitecruzr.blogspot.com/2006/0...ing-using.html
Then look at logs from "browstat status" and "ipconfig /all", from each
computer, so we can diagnose the problem. Read this article, and linked
articles, and follow instructions precisely (download browstat!):
<http://nitecruzr.blogspot.com/2005/05/troubleshooting-network-neighborhood.html#AskingForHelp>
http://nitecruzr.blogspot.com/2005/0...#AskingForHelp
Cheers,
Chuck, MS-MVP [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
networking problem Vista & XP Vista General
Problem networking XP & Vista Vista networking & sharing
Another XP & Vista networking problem. Vista networking & sharing
Vista Networking problem with VPN Vista networking & sharing
Different Vista XP networking problem Vista networking & sharing
