| | Possible Offline files problem causeing laptops to take an age to start/wake. Hi, We run several laptops that seem to have issues with Vista during start-up and returning from sleep. They seem to take a huge amount of time before the HDD stops thrashing and for the systems to become responsive. After the laptops wake from sleep, often they become very unresponsive to the point that some applications simply stop working (such as task manager). When trying to reboot they will hang on the "Windows is Shutting Down" screen, at which point they need to be hard reset. I had thought that the problem was due to the search indexer, but I now believe this is due to offline files. I notice that there is a lot of network activity on the Wi-Fi connection when the laptops start and in resource monitor, there seems to be a large amount of activity in the windows\csc folder. All of these file are being accessed using normal priority. Maybe being able to set these to background priority would elevate the problem slightly. We have around 1GB of information that is stored in offline folders (with a maximum allowed of around 9GB on most laptops), but the vast majority of these do not change on a regular occurrence. So why does Vista seemingly keep having to synchronise all these files? Is there a way I can determine for sure that offline folders are the problem, and if so can I set it so that is does not consume all the resorces of the computer, especially on start up which is probably that most important time when you want to get working on the computer as quickly as possible. Chris |
| Problem reconnecting offline files when mapped as a drive | Vista networking & sharing | |||
| Sync problem - Offline files. | Network & Sharing | |||
| Problem with offline files in Vista and OpportunisticLocking | Vista General | |||
| Offline Files Problem | Vista General | |||
| offline files problem | Vista networking & sharing | |||
