Vista - Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue
Old 07-21-2007   #1 (permalink)
p0wertech
http://blog.tmcnet.com/blog/tom-keat...lem-solved.asp
In the above-mentioned article, Tom Keating describes how he has found the
issue in Windows Vista which causes Remote Desktop Connection (RDC) to either
fail to connect, or operate extremely slow.
In my experiences, I was trying to connect to Windows 2003 Server and
Windows XP based systems from my Windows Vista (Home Premium) operating
system using RDC. Each time I would try, the connection would stop
completely after opening the window and drawing a small portion of my remote
system's desktop.
After searching the internet for over an hour, I found Mr. Keating's article
and executed the following instructions:
1) Open Command Prompt (START - PROGRAMS - ACCESSORIES - COMMAND PROMPT) as
an Administrator by right-clicking on Command Prompt.
2) Type: netsh interface tcp set global autotuninglevel=disabled
This command disables TCP Auto Tuning which is the cause of this particular
problem. To re-enable it, execute the following:
2) Type: netsh interface tcp set global autotuninglevel=normal
If you're technically savvy, there's much more to this issue (fine tuning
the problem, etc), so I recommend reading this article in Mr. Keating's blog.
But for the layman, this quick fix will solve the problem of not being able
to connect to <Vista Operating Systems.
And to Microsoft - recognize this problem and PUT A SOLUTION IN THE
KNOWLEDGEBASE!
Enjoy and good luck!
Old 07-21-2007   #2 (permalink)
Kerry Brown
Re: Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue
> KNOWLEDGEBASE!
A quick search of Microsoft turned up these articles.
http://support.microsoft.com/kb/934430
http://www.microsoft.com/technet/tec...y/default.aspx
http://blogs.msdn.com/wndp/archive/2...-on-vista.aspx
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
Old 03-24-2008   #3 (permalink)
Vista Ultimate
Quote  Quote: Originally Posted by p0wertech View Post
Remote Desktop slow problem solved
system's desktop.
KNOWLEDGEBASE!
when i try to disable the autotuninglevel, it said:
set global command failed on IPv4 The requested operation requires elevation.
i am running as administator.
anyone knows how to solve this problem? i read microsoft's article. i am using Cisco 800 series router (supplied by my cable provider). my RDP session has this problem: when i RDP to my office pc from home, everything is fine; however, when my remote RDP is on (from home) and i come back to office and log into my pc, i get the problem you guys mentioned. The pc only shows small portion of screen. It takes 10 minutes to return the normal state.
I use Vista Ultimate. 32bits Dell PC.
thanks,
Dan
Old 03-24-2008   #4 (permalink)
Robert L. \(MS-MVP\)
Logon administrator is not good enough. You need to run elevation command
prompt. This link may help.
netsh commandSet command failed requested operation requires elevation.
Netsh is a command-line scripting utility that allows you to, either locally
or remotely, ...
www.chicagotech.net/netsh.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"duanyang" <duanyang.36s3w4@xxxxxx-mx.forums.net> wrote in message
news:duanyang.36s3w4@xxxxxx-mx.forums.net...
Quote:
> p0wertech;390696 Wrote:
Quote:
>> 'Remote Desktop slow problem solved'
>> (http://blog.tmcnet.com/blog/tom-keat...lem-solved.asp)
>> the
>> either
>> operating
>> remote
>> system's desktop.
>> article
>> PROMPT) as
>> particular
>> PROMPT) as
>> tuning
>> blog.
>> able
>> KNOWLEDGEBASE!
> elevation.
> thanks,
> Dan
> duanyang
Old 03-24-2008   #5 (permalink)
esk
vista 32 bit
I am similar slowness with RDP. Unfortunately even after implementing below changes, it is still very slow.
I am trying to connect from home m/c(vista) to windows terminal server work m/c (windows xp).
Any other ideas?
Thanks
system's desktop.
KNOWLEDGEBASE!
invalid connection file on remote desktop connection Vista General
Remote Desktop Connection issue Vista networking & sharing
Vista Remote Desktop connection slow with show local devices selected Vista performance & maintenance
Vista SP1 Remote Desktop Connection issue Vista General
Remote Desktop Connection Issue Vista General
