start
programs
accessories
command prompt (right click and select run as administrator and
acknowledge the prompt)
ipconfig /all [enter]
click the icon on the menubar on the left and then edit, select all
(it will turn white)
click the icon in the menubar again then edit, copy
this copies to the clipboard.
paste into a reply
On Wed, 25 Jul 2007 06:00:02 -0700, Magda
<Magda@discussions.microsoft.com> wrote:
>where can i find it???
>i have been told from somebody something about a mac adress...what is
>this??? i don't know where to find it and how to use it
>"Barb Bowman" wrote:
>> do you get an IP?
>> is this a mismatch on security?
>> can you post the complete text of
>> ipconfig /all?
>> On Tue, 24 Jul 2007 14:08:09 -0700, Magda
>> >hello,
>> >i bought a new pc with windows vista in austria and wireless worked
>> >perfectly....now i am in spain and suddenly wireless doesn't work any
>> >more...my laptop can find some different wireless connections with are around
>> >but can't connect with any...the error is undefined...it can't repair
>> >it...nothing works
>> >firewall is off, DNA & IP adress are applied automatically; and in the
>> >internet options i don't choose a connection. (sorry, but i don't know the
>> >proper names in english - i hope you know what i mean)
>> >today i bought an wireless adapter (i thought that it maybe will work) but
>> >it doesnt work either:
>> >the problem is that i don't have access to any modem. i just have the
>> >wireless connection!
>> >i hope i made myself clear and somebody could help me.
>> >thx a lot, Magda
>> Barb Bowman
>> MS Windows-MVP
>> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
>> http://blogs.digitalmediaphile.com/barb/
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/
