| | vista laptop onto bt home hub running on xp Help! I had all my pcs and laptops running xp on the bt home hub. I upgraded my laptop to vista and am now battling to connect to the home network and shared printer on a xp pc. I have enabled private and can connect to the internet but I cant connect to the printer or see shared drives on the other pcs. when i do a network map i see the pcs. what am i doing wrong or have i not done? |
| | Re: vista laptop onto bt home hub running on xp If you can see XP but access, it could be the permission issue. these posts may help, Vista cannot access others Vista: Can't see the TabletPC ... My Vista desktop can't see, or access, the TabletPC come hell or high water. I have matching user accounts on both . ... http://www.chicagotech.net/vista/vistaaccess1.htm - Similar pages chicagotech.net :: View topic - Vista common issue - can see but ... Vista Permission IssuesVista common issue - can see but access ... So, the common issues sharing are 1) you may be able to see it but access. ... http://www.chicagotech.net/netforums...opic.php?t=450 Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Dumb Blonde?" <Dumb Blonde?@discussions.microsoft.com> wrote in message news:956E12CB-FF22-4CA9-B97A-133587313E17@microsoft.com... Help! I had all my pcs and laptops running xp on the bt home hub. I upgraded my laptop to vista and am now battling to connect to the home network and shared printer on a xp pc. I have enabled private and can connect to the internet but I cant connect to the printer or see shared drives on the other pcs. when i do a network map i see the pcs. what am i doing wrong or have i not done? |
| | Re: vista laptop onto bt home hub running on xp On Thu, 2 Aug 2007 15:08:00 -0700, Dumb Blonde? <Dumb Blonde?@discussions.microsoft.com> wrote: >Help! I had all my pcs and laptops running xp on the bt home hub. I upgraded >my laptop to vista and am now battling to connect to the home network and >shared printer on a xp pc. I have enabled private and can connect to the >internet but I cant connect to the printer or see shared drives on the other >pcs. when i do a network map i see the pcs. what am i doing wrong or have i >not done? The first thing with Vista is setting the Network Location Type to Private ("enabled private"??). But Vista has other peculiarities. <http://nitecruzr.blogspot.com/2006/12/windows-xp-and-vista-on-lan-together.html> http://nitecruzr.blogspot.com/2006/1...-together.html And make sure that there are no other firewalls, improperly configured. And make sure that NetBT is consistently enabled. <http://nitecruzr.blogspot.com/2006/07/advanced-windows-networking-using.html> http://nitecruzr.blogspot.com/2006/0...ing-using.html If no help yet, look at logs from "browstat status", "ipconfig /all", "net config server", and "net config workstation", from each computer, and diagnose the problem. Read this article, and linked articles, and follow instructions precisely (download browstat!): <http://nitecruzr.blogspot.com/2005/05/troubleshooting-network-neighborhood.html#AskingForHelp> http://nitecruzr.blogspot.com/2005/0...#AskingForHelp -- Cheers, Chuck, MS-MVP 2005-2007 [Windows - Networking] http://nitecruzr.blogspot.com/ Paranoia is not a problem, when it's a normal response from experience. My email is AT DOT actual address pchuck mvps org. |
| | RE: vista laptop onto bt home hub running on xp http://www.microsoft.com/technet/net.../vista_fp.mspx The above link should help. 1. Make sure that ALL computers have the same worgroup name. XP had MSHOME, and Vista has WORKGROUP by default. Change one of them! 2. Invista Network Sharing: Network discovery ON 2. " " " : Password Protect OFF 3. : File Sharing ON 3. to hook up your XP printer from Vista, in Vista's net sharing, click on "ADd Network Device", and follow the prompts to find the XP's printer. "Dumb Blonde?" wrote: > Help! I had all my pcs and laptops running xp on the bt home hub. I upgraded > my laptop to vista and am now battling to connect to the home network and > shared printer on a xp pc. I have enabled private and can connect to the > internet but I cant connect to the printer or see shared drives on the other > pcs. when i do a network map i see the pcs. what am i doing wrong or have i > not done? |
| Cannot install WML on laptop running Vista | Live Mail | |||
| Trouble adding laptop running Windows Vista to home network | Vista networking & sharing | |||
| I want to do MORE to keep this Vista laptop running well... | Vista General | |||
| New laptop with 4965 agn card running vista home premium | Vista networking & sharing | |||
| Can't print from from wireless laptop running Vista home premium | Vista networking & sharing | |||
