Vista - printer sharing problem xp to vist
Old 08-23-2007   #1 (permalink)
carlarch
I have my hp 7960 installed on my xp machine but I can't connect to it
through the network from my vista machine. I can share all files and folders,
etc. just not the printer. I get an error "windows cannot connect to the
printer. the specified print monitor is unknown". I have no problems sharing
my hp 430 designjet, connect without a problem. Any help would be appreciated.
thanks
carl
Old 08-23-2007   #2 (permalink)
mikem
RE: printer sharing problem xp to vist
I have a similiar problem. I can not connect to my HP laserjet 1200 printer
connected to my desktop computer running windows XP from my HP laptop
running Windows Vista. I can see all other shared folders and can see the
printer but when I try to connect I get the message "windows cannot connect
to the printer: access is denied". Note: did not have a problem with my old
windows XP laptop and i updated the drivers on both machines.
> thanks
> carl
Old 08-23-2007   #3 (permalink)
Malke
Re: printer sharing problem xp to vist
Did you install the Vista drivers from HP on your Vista machine? If you
didn't, that's your next step.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 08-24-2007   #4 (permalink)
carlarch
I did install the vista drivers on the vista machine but it always goes back
to the xp machine to get the drivers when I try to set up the connection for
the network printer.
> Malke
> "Don't Panic!"
Old 08-24-2007   #5 (permalink)
Malke
It should not do that. Remove all the HP printer stuff from your Vista
machine. Now install the Vista drivers (which you will get from HP's
website). Here are links to HP's instructions how to install the printer
in a network:
Installing the Printer on a Wired Network Using the Drivers Provided in
the Windows Vista Operating System
http://tinyurl.com/2wqttw
Setting Up the Printer in a Locally Shared Environment
http://tinyurl.com/2vcg7z
Malke
"Don't Panic!"
Old 08-25-2007   #6 (permalink)
Strycar
After about 15 hrs. of trying to get my vista laptop to print through my xp
desktop via wireless router, I finally found this free download. It works
great. You need to download the software to both machines. Hope this helps.
http://www.networkmagic.com/
> thanks
> carl
Old 08-25-2007   #7 (permalink)
Strycar
After approx. 15 hrs. of getting "access denied" trying to get my vista
laptop to print through my xp machine via wireless router, I finally found
this free download. It may not be the same error message as yours but I
think this will work. You will need to install on both machines. It works
perfect on my system! Here's the address. http://www.networkmagic.com/
> thanks
> carl
Old 08-25-2007   #8 (permalink)
Malke
I'm sorry that you had such a hard time networking your computers. I'm
glad you found a solution, but for most people a third-party program is
unnecessary.
Malke
"Don't Panic!"
Printer sharing problem General Discussion
Sharing printer problem Vista print fax & scan
Printer Sharing problem Network & Sharing
Problem in sharing printer Vista networking & sharing
Printer Sharing problem Vista networking & sharing
