strange networking problem
  1. #1
    Giovanni Guest
    I have 2 laptops running Vista, I have my wireless router setup and both
    computers are connected to the internet fine.
    I can see them in the network map but I can not access from any of the two
    to the other one, I can not ping any of the two from the other one.
    In Vista Networking and Sharing:
    1 Network Discovery ON
    2 File Sharing ON
    3 Public Folder Sharing ON
    4 Password Protected OFF
    5 Network is “Private”
    6 workgroup names are the same "WORKGROUP"
    Thanks for any suggestion
  2. #2
    Malke Guest
    Re: strange networking problem
    > 2 File Sharing ON
    Firewall misconfiguration?
    Configure firewalls on all machines to allow the Local Area Network
    (LAN) traffic as trusted. With Windows Firewall, this means allowing
    File/Printer Sharing on the Exceptions tab. Normally running the Network
    Setup Wizard on XP will take care of this for those machines.The only
    "gotcha" is that this will turn on the XPSP2 Windows Firewall. If you
    aren't running a third-party firewall or have an antivirus with
    "Internet Worm Protection" (like Norton 2006/07) which acts as a
    firewall, then you're fine. With third-party firewalls, I usually
    configure the LAN allowance with an IP range. Ex. would be
    192.168.1.0-192.168.1.254. Obviously you would substitute your correct
    subnet. Do not run more than one firewall.
    Malke
    Elephant Boy Computers
    www.elephantboycomputers.com
    "Don't Panic!"
    MS-MVP Windows - Shell/User
  3. #3
    Giovanni Guest
    Great Malke!
    I have configured the firewall in Windows Live One Care and it works. I
    completely forgotted about this possibility, I wonder why the changes in the
    connections management panel do not change the firewall.
    Thanks
  4. #4
    Malke Guest
    Giovanni wrote:
    > Great Malke!
    > Thanks
    Glad that sorted it for you. Thanks for taking the time to let me know.
    Malke
    "Don't Panic!"
strange networking problem problems?
Please help!! very strange problem!! smwilmann Sound & Audio 2 12 Dec 2008
Strange problem networking two vista boxes 32 bit and 64 bit 1361 Vista networking & sharing 3 05 Jun 2008
strange networking problem jared Vista hardware & devices 1 21 May 2008
Very strange problem networking Vista to XP (wireless) pctotil Vista networking & sharing 21 24 Apr 2008
ACPI problem but no problem at all - Strange thing Marco Vista installation & setup 2 23 Feb 2007
