| | WiFi Signal Strength: No Signal Since installing Beta 5456 the signal strength icon has started claiming "No Signal" even though I have successfully setup a wireless connection and connected OK to the Internet. If I disconnect the network, the WiFi connection appears in the list and the signal strength is shown as excellent (5 bars). If I then select the connection and click the "Connect" button, Vista shows the acquiring IP address dialog; then says I am connected but with "limited connectivity". At this point, the signal strength is showing as "No Signal" again. Despite this, I have a good connection to the Internet (confirmed by the network map). Is this a known problem / bug? It was working OK in the public Beta 2. NRM Smith |
| | Re: WiFi Signal Strength: No Signal The happened to me with the prior release (all I can get). Happened after an automatic update to my Intel 2915abg driver. I rolled back and it fixed it. "nrms" <nrms@discussions.microsoft.com> wrote in message news:9539E4CC-45EB-4DEC-B67D-8687C33F0AC9@microsoft.com... > Since installing Beta 5456 the signal strength icon has started claiming > "No > Signal" even though I have successfully setup a wireless connection and > connected OK to the Internet. If I disconnect the network, the WiFi > connection appears in the list and the signal strength is shown as > excellent > (5 bars). If I then select the connection and click the "Connect" button, > Vista shows the acquiring IP address dialog; then says I am connected but > with "limited connectivity". At this point, the signal strength is > showing > as "No Signal" again. Despite this, I have a good connection to the > Internet > (confirmed by the network map). > > Is this a known problem / bug? It was working OK in the public Beta 2. > > NRM Smith > |
| network signal strength indicator | Vista networking & sharing | |||
| Signal strength for DVB-T& signal in Windows Vista Home Premium MC | Vista General | |||
| wireless signal strength | Vista networking & sharing | |||
| Wireless Signal Strength | Vista networking & sharing | |||
| wireless signal strength problems | Vista General | |||
