Vista - Re: internet connection problems
Old 09-01-2007   #1 (permalink)
Robert Aldwinckle
(cross-post added to Vista Networking)
"totalguy" <totalguy@xxxxxx> wrote in message
news:1BC8DE63-520F-4618-B531-FC904FEE71C9@xxxxxx
Quote:
>I have an internet connection problem on my DELL computer, my ISP says its a
> vista issue as there is no problems with my connection, which seems correct
> because it was running fine on windows xp.
Quote:
> Microsoft say that dell modify
> internet explorer to meet their requirements and dell cannot help they say
> the issue lies with microsoft so im stuck!
Quote:
> I think what i need to do is somehow remove or install over internet
> explorer 7 but how???
Since the biggest change was XP to Vista, not a change in IE
you could try using a different browser and compare problem symptoms
from it.
Quote:
> I cant see how its been modified, maybe in the background?
Quote:
> the problem im having is occasionally when iclick links i get page not found
> and if i go back and try again it works,
That's unfortunate but not uncommon. E.g. it would mean that your ISP's
service was borderline and Vista was the tipping point for it.
Quote:
> but thats not the worst part, a few times a day
> i have to restart my computer because i cannot display any web pages until i
> do. i have tried many methods to repair the problem without restarting my
> computer but to no avail
Such as? You should not have to restart your computer just to refresh
your link to the Internet.
BTW as this has more to do with your OS than with IE (especially
if your link can only be restarted by rebooting), you may get more
informed help from a newsgroup which specializes in networking
for Vista.
Good luck
Robert Aldwinckle
Quote:
> Darrell
Old 09-01-2007   #2 (permalink)
Robert
OK, i can not find where to ask a question on this news group!
My queswtion is:
ie7 will not read html code generated by front page 2003 to follow a link
from a click on a .jpg. The icon is in a frame. It works in all previous
versions of ie and in firefox, etc.
Please tell me how to start a thread!
Robert
> from it.
> for Vista.
> Good luck
> Robert Aldwinckle
Quote:
> > Darrell
Old 09-02-2007   #3 (permalink)
totalguy
How do i do that? i have issues using this message board as it is lol. its
not exactly laid out well.
Darrell
> from it.
> for Vista.
> Good luck
> Robert Aldwinckle
Quote:
> > Darrell
Old 09-02-2007   #4 (permalink)
Robert Aldwinckle
"Robert" <Robert@xxxxxx> wrote in message
news:AEDA2FC3-6521-4CDB-99D4-E72B7EFCB3CE@xxxxxx
Quote:
> [X-Newsreader: Microsoft CDO for Windows 2000]
Where are you posting from? I cross-posted this from IE General
to Vista Networking for the OP. Please start your own thread in
IE General only. If you must hijack someone else's thread
at least please choose one which is not cross-posted!
(And try doing a search to find one which is more relevant to your problem
anyway.)
You are using a web interface to newsgroups.
The UI for your interface may depend on the specific portal you are using.
We don't know the portal you are using unless you post the URL that you have
in your Address bar.
If your UI has a Help button try using it. E.g. there is a link in there which
specifically explains how to "Post a new question".
http://www.microsoft.com/wn3/locales...ostNewQuestion
In case you can't spot the New button in your UI try also searching in the Help
for keyboard shortcuts. Usually you can start a new thread by clicking on the
New button or by pressing Alt-M,Enter and using the New button's popup menu.
If you don't see a popup menu it's possible that you have a popup stopper
active which is inhibiting its display; so then you would have to disable that.
Etc.
Quote:
> My queswtion is:
Are you using Vista? There are already several discussions about problems
rendering images on it in the IE General newsgroup, mostly about .png images
but perhaps the same ideas (such as using Run As... Administrator) would
work.
See above and try searching before posting. ; }
HTH
Robert Aldwinckle
Old 09-02-2007   #5 (permalink)
Robert Aldwinckle
news:40E806DC-D50E-4E68-819C-7CB914219B5D@xxxxxx
That? What? I gave you more than one suggestion. ; ]
Quote:
>> from it.
Hopefully there is a Firefox or other browser proponent who would be more
than pleased to help you do that... ; }
Quote:
Quote:
>> you may get more informed help from a newsgroup which specializes
>> in networking for Vista.
I have already cross-posted your question to a newsgroup for Vista Networking.
Since you are using a web interface to newsgroups, depending on the portal
you are using you may be able to enter that newsgroup simply by clicking on
the other newsgroup's name in the header of this post.
Good luck
Robert
Quote:
> Darrell
>> from it.
>> for Vista.
>> Good luck
>> Robert Aldwinckle
Quote:
>> > Darrell
Old 09-02-2007   #6 (permalink)
Robert
Hello Robert A-
Thanks for your resonce! I will read up on the process and re-post my
observation on ie7 in the right place (I hope ;-).
I do not think it is a vista problem since ie7 acts the same on an xp machine.
Will I get free software if I have discovered a glitch??
--Bob S
PS: What is a UI?
http://www.microsoft.com/communities...7-a97f8fe70fea
> anyway.)
> Etc.
Quote:
> > My queswtion is:
> work.
> HTH
> Robert Aldwinckle
Old 09-02-2007   #7 (permalink)
totalguy
i tried updating network drivers, i tried resetting the modem, i tried
repairing by using windows vista repair thing but that never worked. i tried
all 5 methods suggested in a previous reply, ive tried a fresh install of
vista, ive tried using a different network card. cant remember everything ive
tried but im sure theres more.
you said: you may get more informed help from a newsgroup which specializes
thats why i said how do i do that.
Darrell
Quote:
> >> from it.
> Good luck
> Robert
Quote:
> > Darrell
> >> from it.
> >> for Vista.
> >> Good luck
> >> Robert Aldwinckle
> >> > Darrell
Old 09-03-2007   #8 (permalink)
Robert Aldwinckle
news:B0DDB8F9-0620-4836-9797-8AC90F4E2A2F@xxxxxx
Quote:
> Hello Robert A-
Fine. All the more reason then not to further confuse this cross-posted
discussion with your interjections. OP very definitely does have a Vista-only
problem.
No.
Quote:
> --Bob S
> PS: What is a UI?
Try a search?
http://msdn2.microsoft.com/en-us/lib...ef(vs.71).aspx
(Live Search for
UI abbreviations site:microsoft.com
<quote>
Where appropriate, use well-known acronyms to replace lengthy phrase names.
For example, use UI for User Interface
</quote>
BTW finding a plain definition of it was harder than I expected.
Evidently it is thought to be so well known that a Glossary item
isn't even necessary!
So, did you try Alt-M,Enter there?
Good luck
Robert
>> anyway.)
>> Etc.
Quote:
>> > My queswtion is:
>> work.
>> HTH
>> Robert Aldwinckle
internet connection problems Browsers & Mail
internet connection problems Network & Sharing
Internet connection problems Vista networking & sharing
SP1 Causes Problems with Internet Connection Vista General
