| Newbie | ? Wireless Network using a WUSB54G adaptor I need help using the following on Vista Windows. I have had no help with tech support and have been talking to them for over 15 hours. All I get is the message "Windows cannot connect to "Me" (this is what I called my network). Can someone tell me what I need to do in order to get a wireless connect with Vista Windows. Thanks |
| Guest | Re: ? Wireless Network using a WUSB54G adaptor motherlove30 wrote: Quote: > I need help using the following on Vista Windows. I have had no help > with tech support and have been talking to them for over 15 hours. All I > get is the message "Windows cannot connect to "Me" (this is what I > called my network). Can someone tell me what I need to do in order to > get a wireless connect with Vista Windows. Thanks > > Internet and what wireless hardware you are using, it's a bit hard to be specific. Whose tech support have you been talking to? I started writing out a rather elaborate troubleshooting triage for you to follow but quickly realized that it will be far easier and simpler for you to just post back with the missing information. 1. How do you connect to the Internet? Cable, DSL, which company? 2. Do you have any other computers that are able to connect to the Internet? 3. What equipment do you have? Do you have a separate cable/DSL modem and a wireless router or a combination modem/router? What makes/models? Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| Newbie | Re: ? Wireless Network using a WUSB54G adaptor Thanks for your help, problem solved. |
| Guest | Re: ? Wireless Network using a WUSB54G adaptor motherlove30 wrote: Quote: > Thanks for your help, problem solved. > > Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| wireless network adaptor problem | Vista networking & sharing | |||
| Wireless adaptor | Vista hardware & devices | |||
| wireless adaptor? what do i have | Vista General | |||
| linksys wireless-g usb network adaptor | Vista hardware & devices | |||
| Linksys Wireless-G WUSB54G + Windows vista [Incident: 060603-00020 | Vista hardware & devices | |||
