| | Internet connection problems I've plugged into my laptop the LAN cable from my desktop computer and the Internet connection works for a few seconds, then in Vista becomes Local Access Only, then drops...then works again for a little bit and so on. From my laptop, I can't ping the default gateway ( router's interface ). I've set up the same IP information , hostname & MAC address as on the desktop computer on the laptop, but it doesn't work. A possible solution? The router is under ISP's administration. |
| | Re: Internet connection problems Post back the results of both computers ipconfig /all may help. Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Mircea Neagoe" <MirceaNeagoe@xxxxxx> wrote in message news:2B735B65-740F-4C94-BAE0-3C58A0190492@xxxxxx I've plugged into my laptop the LAN cable from my desktop computer and the Internet connection works for a few seconds, then in Vista becomes Local Access Only, then drops...then works again for a little bit and so on. From my laptop, I can't ping the default gateway ( router's interface ). I've set up the same IP information , hostname & MAC address as on the desktop computer on the laptop, but it doesn't work. A possible solution? The router is under ISP's administration. |
| Win XP Pro / Win Vista Ultimate | Re: Internet connection problems reinstall the NIC driver and the chipset driver. try another cable. |
| | RE: Internet connection problems On the laptop, Ipconfig reports NIC's real MAC address, not the spoofed one...after configuring it in device manager ( network address attribute in NIC properties ) and rebooting. "Mircea Neagoe" wrote: Quote: > I've plugged into my laptop the LAN cable from my desktop computer and the > Internet connection works for a few seconds, then in Vista becomes Local > Access Only, then drops...then works again for a little bit and so on. > From my laptop, I can't ping the default gateway ( router's interface ). > I've set up the same IP information , hostname & MAC address as on the > desktop computer on the laptop, but it doesn't work. > A possible solution? > > The router is under ISP's administration. |
| internet connection problems | Browsers & Mail | |||
| internet connection problems | Network & Sharing | |||
| Internet connection problems | Vista networking & sharing | |||
| SP1 Causes Problems with Internet Connection | Vista General | |||
| Re: internet connection problems | Vista networking & sharing | |||
