Vista - Vista Home Premium on XP Pro network won't print
Old 09-08-2007   #1 (permalink)
Buswrench43
I have an existing Windows XP Pro wireless network, and just recently
purchased a Vista home Premium laptop. I added the lap top to the network and
all works well. Then I tried to add a printer to the laptop, it added, and
can be seen on the network. When I try to print a test page, it does not
print and the printer on the laptop shows error, but has no error code. Help
Old 09-08-2007   #2 (permalink)
Malke
Re: Vista Home Premium on XP Pro network won't print
Since you left out the details of how you added the printer... did you
get the latest Vista drivers from the printer mftr.'s website and
install them on the Vista machine? Your error indicates incorrect drivers.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 09-11-2007   #3 (permalink)
Buswrench43
> Malke
> "Don't Panic!"
Yes, I did download the correct driver from the Canon website. I think I
need to make a virtual USB port, (not sure how to do it) There is really no
correct port listing on the Vista Laptop to make it print. Thanks for your
reply!
Unable to print from Vista Home Premium to XP Home Vista networking & sharing
Unable to Print or Print Preview from IE7 on Vista Home Premium Vista print fax & scan
Print to fax (Vista Home Premium) Vista print fax & scan
Re: IE7 in Vista Home Premium won't print anything Vista print fax & scan
