| | Printing issues from XP Pro laptop to Vista Home Premium PC I have issues when trying to print from applications, such as Word or Notepad, from my XP laptop. The printer (Konica Minolta 2500w Color Laser, USB) is connected to my Vista Home Premium PC. Documents print fine from the PC itself. The strange thing is I can print a test page from the XP laptop, from the General tab on the Printer Properties page, but when I try to print from an application I get errors and nothing prints (and nothing even shows up in the print queue). The errors vary depending on the application I am trying to print from. I have double checked my network settings and ensured that: all computers are in the same workgroup printer sharing is turned on password protection is turned off Other network functions appear fine (file sharing for example). I have tried un-installing the printer and installing the latest drivers, but the same situation occurs. Any suggestions appreciated! |
| | RE: Printing issues from XP Pro laptop to Vista Home Premium PC I am having the exact same issue, although I can't even print a test page. I have 2 XP PCs on the network and the printer is on a Vista machine. One XP PC prints fine, and the other can't even find the printer on the network. Since one XP PC works fine, I think my Vista machine is set up correctly. Any information on this issue would help. "TheJudge" wrote: Quote: > I have issues when trying to print from applications, such as Word or > Notepad, from my XP laptop. > > The printer (Konica Minolta 2500w Color Laser, USB) is connected to my Vista > Home Premium PC. Documents print fine from the PC itself. > > The strange thing is I can print a test page from the XP laptop, from the > General tab on the Printer Properties page, but when I try to print from an > application I get errors and nothing prints (and nothing even shows up in the > print queue). The errors vary depending on the application I am trying to > print from. > > I have double checked my network settings and ensured that: > all computers are in the same workgroup > printer sharing is turned on > password protection is turned off > > Other network functions appear fine (file sharing for example). > > I have tried un-installing the printer and installing the latest drivers, > but the same situation occurs. > > Any suggestions appreciated! |
| | RE: Printing issues from XP Pro laptop to Vista Home Premium PC I don't know what I did, but it is working now. I made sure user names are the same for all PCs in the network. I don't have passwords enabled. I made sure the public folder on the Vista machine was visible from all PCs. For some reason, the network printer was then visible from the laptop. Not sure what I did that made it work. "dmckenney" wrote: Quote: > I am having the exact same issue, although I can't even print a test page. I > have 2 XP PCs on the network and the printer is on a Vista machine. One XP > PC prints fine, and the other can't even find the printer on the network. > Since one XP PC works fine, I think my Vista machine is set up correctly. > Any information on this issue would help. > > "TheJudge" wrote: > Quote: > > I have issues when trying to print from applications, such as Word or > > Notepad, from my XP laptop. > > > > The printer (Konica Minolta 2500w Color Laser, USB) is connected to my Vista > > Home Premium PC. Documents print fine from the PC itself. > > > > The strange thing is I can print a test page from the XP laptop, from the > > General tab on the Printer Properties page, but when I try to print from an > > application I get errors and nothing prints (and nothing even shows up in the > > print queue). The errors vary depending on the application I am trying to > > print from. > > > > I have double checked my network settings and ensured that: > > all computers are in the same workgroup > > printer sharing is turned on > > password protection is turned off > > > > Other network functions appear fine (file sharing for example). > > > > I have tried un-installing the printer and installing the latest drivers, > > but the same situation occurs. > > > > Any suggestions appreciated! |
| Desktop can't see laptop, Laptop can see Desktop (home premium network issues) | Vista networking & sharing | |||
| Problems printing to a network Vista home premium computer | Vista print fax & scan | |||
| Printing from XP Laptop to Vista Desktop issues | Network & Sharing | |||
| Fax Printing - Vista Home Premium | Vista General | |||
| Printing problem from XP Wireless to Vista Home Premium Desktop PC | Vista networking & sharing | |||
