Vista Tutorial - Remote Desktop - Vista home premium to XP Pro
Old 09-20-2007   #1 (permalink)
Elrod
Guest
Using VPN I can connect XP to XP Pro. The only issue was setting up a
firewal exclusion for "remote desktop". This option is either hidden or
unavailable with VISTA Home Premium.
In either case, I'm unable to logon to the XP pro machine with VISTA. I see
the start of the remote connection, but get a login error message requesting
credentials.
Old 09-21-2007   #2 (permalink)
Elrod
Guest
RE: Remote Desktop - Vista home premium to XP Pro
After a ton of perusing, I finally read the solution.
With XP you only need the host's computer name.
With VISTA Home Premium, you need the host's full computer name.
Start | Control Panel | System | Computer Name tab.
> credentials.
Remote desktop from Vista Home Premium to XP Pro Vista General
Remote desktop from Vista Home Premium to XP Pro Vista networking & sharing
Remote Desktop with Vista Home Premium 64? Vista General
Remote Desktop - XP Home taking control of Vista Home Premium Vista General
Windows Vista Home Premium and Remote Desktop Vista General
