| | Re: plz help-LAN trouble with 3 PC's My networking is incredibly buggy. Try \\computername from the "Start Search" box at the bottom of the Start Menu and see if Vista finds the other computer. This last resort always works for me. "spok" <spoo@verizn.net> wrote in message news:5481BD0D-F2CD-4B0B-BB7F-28D624342297@microsoft.com... > 2nd post here. > If more info is needed pls ask or tell me what it is that is needed. > 3 PC's > 1st PC--dual boot--vista--xp pro,sp2. > 2nd PC--dual boot--xp--982nd ed---2000 > 3rd PC Win ME. > > I can see the Vista--(Public) PC from both other PC's. Can not get access > though. > Vista PC can not see any of the other PC's > Vista can get online > Verizon DSL-westell modem---D-Link router DL-604, ethernet cabled. > everything works fine between the PC's except for the vista OS. > > In the NETWORK CENTER, I have it set to "ALLOWED". In the network file and > print sharing, I have everything set to what looks like the least > difficult permissions. (allow anyone to connect to my network. allow > anyone to change files etc... > > When I try to move a folder from 2nd PC-""cannot creat or replace (folder > name) Access denied > Make sure the disk is not full orwrtite-protected, and that the file is > not currently in use" > which doesn't sound like a networking problem to me. > > see no problems in device manager > > I would really like to over come this problem but am stuck at the moment, > what to try nexrt. > I even went as far as to load NET-BEUI, because it used to be my last > resort for networking, it always came through for me. Not this time, and I > don't even know if vista will work with NET-BEUI? it did let me add it to > the protocols. > > PLEASE- someone give me some advice here. > Thanks in advance > > |
| | Re: plz help-LAN trouble with 3 PC's - Are the Vista PC and the Windows XP PC's in the same workgroup? - In Network File and Printer Sharing, setting Network Access to "Anyone with a user account and password for this computer" and Public Folder to "Allow people with network access to open, change and create files" should give you write access to your Vista machine from other computers. You will have to log in from the other machine first, though (this is the same behavior as Windows XP). |
| | plz help-LAN trouble with 3 PC's 2nd post here. If more info is needed pls ask or tell me what it is that is needed. 3 PC's 1st PC--dual boot--vista--xp pro,sp2. 2nd PC--dual boot--xp--982nd ed---2000 3rd PC Win ME. I can see the Vista--(Public) PC from both other PC's. Can not get access though. Vista PC can not see any of the other PC's Vista can get online Verizon DSL-westell modem---D-Link router DL-604, ethernet cabled. everything works fine between the PC's except for the vista OS. In the NETWORK CENTER, I have it set to "ALLOWED". In the network file and print sharing, I have everything set to what looks like the least difficult permissions. (allow anyone to connect to my network. allow anyone to change files etc... When I try to move a folder from 2nd PC-""cannot creat or replace (folder name) Access denied Make sure the disk is not full orwrtite-protected, and that the file is not currently in use" which doesn't sound like a networking problem to me. see no problems in device manager I would really like to over come this problem but am stuck at the moment, what to try nexrt. I even went as far as to load NET-BEUI, because it used to be my last resort for networking, it always came through for me. Not this time, and I don't even know if vista will work with NET-BEUI? it did let me add it to the protocols. PLEASE- someone give me some advice here. Thanks in advance |
| how many PC's can run one copy | Vista account administration | |||
| Network PC's Where Are You | Vista General | |||
| all pc's vista and no RDP | Vista networking & sharing | |||
| Networking with XP pc's | Vista General | |||
| PC's still with XP | Vista General | |||
