| | Vista & XP Network - Wired WORKS - Wirless does NOT Work Hi: I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I have tried to set it up to connect to my home network through my Trendnet TEW-431BRP router, but I am not having any luck. Here is what is happeing: VISTA MACHINE: - Can use Internet - Cannot See XP Machine - Cannot Share Files or Printers on XP XP MACHINE (LLTD Installed, wired into router): - Can use Internet - Can See VISTA Machine - Cannot Share Files on VISTA Same workgroup for both PC's. I have actually shared some specific directories on both machines. Same ID and Password on both machines. Network Discovery is turned on on the Vista machine I finally decided to try a Wired Connection and all is working as expected. I am using ZoneAlarm on both machine and have put all my home network addresses into the Trusted setting. Any ideas as to why it doesn't work when using WIRELESS? Thanks in advance. |
| | Re: Vista & XP Network - Wired WORKS - Wirless does NOT Work With wireless connection, can you ping each other? -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "TheTraveller" <TheTraveller@xxxxxx> wrote in message news 36F10F2-8B90-4ED7-B9B7-800BA6F4BBEA@xxxxxxQuote: > Hi: > > I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I > have > tried to set it up to connect to my home network through my Trendnet > TEW-431BRP router, but I am not having any luck. Here is what is > happeing: > > VISTA MACHINE: > - Can use Internet > - Cannot See XP Machine > - Cannot Share Files or Printers on XP > > XP MACHINE (LLTD Installed, wired into router): > - Can use Internet > - Can See VISTA Machine > - Cannot Share Files on VISTA > > Same workgroup for both PC's. I have actually shared some specific > directories on both machines. Same ID and Password on both machines. > Network Discovery is turned on on the Vista machine > > > I finally decided to try a Wired Connection and all is working as > expected. > > I am using ZoneAlarm on both machine and have put all my home network > addresses into the Trusted setting. > > Any ideas as to why it doesn't work when using WIRELESS? > > Thanks in advance. |
| | Re: Vista & XP Network - Wired WORKS - Wirless does NOT Work I have the exact same issue with a VISTA Lenovo Laptop wired -- everything works as expected wireless -- although I can get out to the internet with problems via my wireless AP in my firewall -- I have numerous "local network issues related to not being able to properly resolve names on the network something is definitely screwed in VISTA wireless.. Swapping harddrives to one with XP on it on same hardware does not have any wireless problems........................ "Robert L (MS-MVP)" <noreply@xxxxxx> wrote in message news:OybxU3CBIHA.4880@xxxxxx Quote: > With wireless connection, can you ping each other? > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "TheTraveller" <TheTraveller@xxxxxx> wrote in message > news 36F10F2-8B90-4ED7-B9B7-800BA6F4BBEA@xxxxxxQuote: >> Hi: >> >> I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I >> have >> tried to set it up to connect to my home network through my Trendnet >> TEW-431BRP router, but I am not having any luck. Here is what is >> happeing: >> >> VISTA MACHINE: >> - Can use Internet >> - Cannot See XP Machine >> - Cannot Share Files or Printers on XP >> >> XP MACHINE (LLTD Installed, wired into router): >> - Can use Internet >> - Can See VISTA Machine >> - Cannot Share Files on VISTA >> >> Same workgroup for both PC's. I have actually shared some specific >> directories on both machines. Same ID and Password on both machines. >> Network Discovery is turned on on the Vista machine >> >> >> I finally decided to try a Wired Connection and all is working as >> expected. >> >> I am using ZoneAlarm on both machine and have put all my home network >> addresses into the Trusted setting. >> >> Any ideas as to why it doesn't work when using WIRELESS? >> >> Thanks in advance. > |
| | RE: Vista & XP Network - Wired WORKS - Wirless does NOT Work http://technet.microsoft.com/en-us/l.../bb727037.aspx "TheTraveller" wrote: Quote: > Hi: > > I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I have > tried to set it up to connect to my home network through my Trendnet > TEW-431BRP router, but I am not having any luck. Here is what is happeing: > > VISTA MACHINE: > - Can use Internet > - Cannot See XP Machine > - Cannot Share Files or Printers on XP > > XP MACHINE (LLTD Installed, wired into router): > - Can use Internet > - Can See VISTA Machine > - Cannot Share Files on VISTA > > Same workgroup for both PC's. I have actually shared some specific > directories on both machines. Same ID and Password on both machines. > Network Discovery is turned on on the Vista machine > > > I finally decided to try a Wired Connection and all is working as expected. > > I am using ZoneAlarm on both machine and have put all my home network > addresses into the Trusted setting. > > Any ideas as to why it doesn't work when using WIRELESS? > > Thanks in advance. |
| | Re: Vista & XP Network - Wired WORKS - Wirless does NOT Work http://technet.microsoft.com/en-us/l.../bb727037.aspx Have a read of the above "Steven Toney" wrote: Quote: > I have the exact same issue with a VISTA Lenovo Laptop > > wired -- everything works as expected > > wireless -- although I can get out to the internet with problems via my > wireless AP in my firewall -- I have numerous "local network issues related > to not being able to properly resolve names on the network > > something is definitely screwed in VISTA wireless.. > > Swapping harddrives to one with XP on it on same hardware does not have any > wireless problems........................ > > > > "Robert L (MS-MVP)" <noreply@xxxxxx> wrote in message > news:OybxU3CBIHA.4880@xxxxxx Quote: > > With wireless connection, can you ping each other? > > > > -- > > Bob Lin, MS-MVP, MCSE & CNE > > Networking, Internet, Routing, VPN Troubleshooting on > > http://www.ChicagoTech.net > > How to Setup Windows, Network, VPN & Remote Access on > > http://www.HowToNetworking.com > > > > > > "TheTraveller" <TheTraveller@xxxxxx> wrote in message > > news 36F10F2-8B90-4ED7-B9B7-800BA6F4BBEA@xxxxxxQuote: > >> Hi: > >> > >> I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I > >> have > >> tried to set it up to connect to my home network through my Trendnet > >> TEW-431BRP router, but I am not having any luck. Here is what is > >> happeing: > >> > >> VISTA MACHINE: > >> - Can use Internet > >> - Cannot See XP Machine > >> - Cannot Share Files or Printers on XP > >> > >> XP MACHINE (LLTD Installed, wired into router): > >> - Can use Internet > >> - Can See VISTA Machine > >> - Cannot Share Files on VISTA > >> > >> Same workgroup for both PC's. I have actually shared some specific > >> directories on both machines. Same ID and Password on both machines. > >> Network Discovery is turned on on the Vista machine > >> > >> > >> I finally decided to try a Wired Connection and all is working as > >> expected. > >> > >> I am using ZoneAlarm on both machine and have put all my home network > >> addresses into the Trusted setting. > >> > >> Any ideas as to why it doesn't work when using WIRELESS? > >> > >> Thanks in advance. > > > |
| | #6 (permalink) |
| | RE: Vista & XP Network - Wired WORKS - Wirless does NOT Work Thanks for all the replies. I did some more digging in my router and it turns it it was the culprit. I was restricting access to the LAN via MAC Address and for some reason it wasn't allowing the Vista Machine to see the LAN even though it's MAC Address was listed in the allowable group. I disabled the MAC Address filtering and all is working fine. "Mick Murphy" wrote: Quote: > http://technet.microsoft.com/en-us/l.../bb727037.aspx > > "TheTraveller" wrote: > Quote: > > Hi: > > > > I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I have > > tried to set it up to connect to my home network through my Trendnet > > TEW-431BRP router, but I am not having any luck. Here is what is happeing: > > > > VISTA MACHINE: > > - Can use Internet > > - Cannot See XP Machine > > - Cannot Share Files or Printers on XP > > > > XP MACHINE (LLTD Installed, wired into router): > > - Can use Internet > > - Can See VISTA Machine > > - Cannot Share Files on VISTA > > > > Same workgroup for both PC's. I have actually shared some specific > > directories on both machines. Same ID and Password on both machines. > > Network Discovery is turned on on the Vista machine > > > > > > I finally decided to try a Wired Connection and all is working as expected. > > > > I am using ZoneAlarm on both machine and have put all my home network > > addresses into the Trusted setting. > > > > Any ideas as to why it doesn't work when using WIRELESS? > > > > Thanks in advance. |
| | #7 (permalink) |
| | Re: Vista & XP Network - Wired WORKS - Wirless does NOT Work Thank you for the update. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "TheTraveller" <TheTraveller@xxxxxx> wrote in message news:34FAA664-FC3F-4BB4-A53C-FE517F337F9F@xxxxxx Quote: > Thanks for all the replies. > > I did some more digging in my router and it turns it it was the culprit. > > I was restricting access to the LAN via MAC Address and for some reason it > wasn't allowing the Vista Machine to see the LAN even though it's MAC > Address > was listed in the allowable group. I disabled the MAC Address filtering > and > all is working fine. > > "Mick Murphy" wrote: > Quote: >> http://technet.microsoft.com/en-us/l.../bb727037.aspx >> >> "TheTraveller" wrote: >> Quote: >> > Hi: >> > >> > I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I >> > have >> > tried to set it up to connect to my home network through my Trendnet >> > TEW-431BRP router, but I am not having any luck. Here is what is >> > happeing: >> > >> > VISTA MACHINE: >> > - Can use Internet >> > - Cannot See XP Machine >> > - Cannot Share Files or Printers on XP >> > >> > XP MACHINE (LLTD Installed, wired into router): >> > - Can use Internet >> > - Can See VISTA Machine >> > - Cannot Share Files on VISTA >> > >> > Same workgroup for both PC's. I have actually shared some specific >> > directories on both machines. Same ID and Password on both machines. >> > Network Discovery is turned on on the Vista machine >> > >> > >> > I finally decided to try a Wired Connection and all is working as >> > expected. >> > >> > I am using ZoneAlarm on both machine and have put all my home network >> > addresses into the Trusted setting. >> > >> > Any ideas as to why it doesn't work when using WIRELESS? >> > >> > Thanks in advance. |
| | #8 (permalink) |
| | Re: Vista & XP Network - Wired WORKS - Wirless does NOT Work I have been through all that stuff I have things configured correctly on all machines.. I have double and triple checked this it is a wireless bug on name resolution and I can find no way to correct it by any configuration changes it simply will not work correctly it is absolutely isolated to wireless networking While on wireless -- I can clearly access my wireless access point, the wireles nic get a IP address and firewall gateway properly and I can always access the internet then problem is accessing other computer on the internal network -- all machines are in the same workgroup, all machine are in the subnet... etc etc the vista laptop simply refuses to name resolve and access other machines on my LAN I have even turned of the computer browser service on all machine except my windows 2003 server box to avoid browser master election problems as I said -- swap in a hard drive with XP and the laptop connects wirelessly perfectly plug in a wired lan cable and the vista laptop work absolutely as exepcted with networking I have another vista machine with only wired networking on the lan and its works perfectly fine on the network.. It has other Vista wierdness with some software like repeated VC++ runtime errors that I can not trace to cause.., but it networks with issues.. I know how to share folders and the like in VISTA without problem the issue for me is clearly this wireless network anomaly with wireless name resolution on the lan. "Mick Murphy" <MickMurphy@xxxxxx> wrote in message news 78E43FB-9BF0-4CF9-BDA4-A9E511A51B2D@xxxxxxQuote: > http://technet.microsoft.com/en-us/l.../bb727037.aspx > > Have a read of the above > > "Steven Toney" wrote: > Quote: >> I have the exact same issue with a VISTA Lenovo Laptop >> >> wired -- everything works as expected >> >> wireless -- although I can get out to the internet with problems via my >> wireless AP in my firewall -- I have numerous "local network issues >> related >> to not being able to properly resolve names on the network >> >> something is definitely screwed in VISTA wireless.. >> >> Swapping harddrives to one with XP on it on same hardware does not have >> any >> wireless problems........................ >> >> >> >> "Robert L (MS-MVP)" <noreply@xxxxxx> wrote in message >> news:OybxU3CBIHA.4880@xxxxxx Quote: >> > With wireless connection, can you ping each other? >> > >> > -- >> > Bob Lin, MS-MVP, MCSE & CNE >> > Networking, Internet, Routing, VPN Troubleshooting on >> > http://www.ChicagoTech.net >> > How to Setup Windows, Network, VPN & Remote Access on >> > http://www.HowToNetworking.com >> > >> > >> > "TheTraveller" <TheTraveller@xxxxxx> wrote in >> > message >> > news 36F10F2-8B90-4ED7-B9B7-800BA6F4BBEA@xxxxxx>> >> Hi: >> >> >> >> I just purchased a Dell Ispiron 1520 with Vista Home Premium on it. I >> >> have >> >> tried to set it up to connect to my home network through my Trendnet >> >> TEW-431BRP router, but I am not having any luck. Here is what is >> >> happeing: >> >> >> >> VISTA MACHINE: >> >> - Can use Internet >> >> - Cannot See XP Machine >> >> - Cannot Share Files or Printers on XP >> >> >> >> XP MACHINE (LLTD Installed, wired into router): >> >> - Can use Internet >> >> - Can See VISTA Machine >> >> - Cannot Share Files on VISTA >> >> >> >> Same workgroup for both PC's. I have actually shared some specific >> >> directories on both machines. Same ID and Password on both machines. >> >> Network Discovery is turned on on the Vista machine >> >> >> >> >> >> I finally decided to try a Wired Connection and all is working as >> >> expected. >> >> >> >> I am using ZoneAlarm on both machine and have put all my home network >> >> addresses into the Trusted setting. >> >> >> >> Any ideas as to why it doesn't work when using WIRELESS? >> >> >> >> Thanks in advance. >> > >> > >> |
| MS Wired Optical Mouse only Works Sometime | Vista General | |||
| fax on wirless network | Vista print fax & scan | |||
| Wirless Network Doesn't work after "hibernation or sleep" mode | Vista networking & sharing | |||
| Vista wirelss networking no work, wired networking works | Vista networking & sharing | |||
| Wired or Wireless Adapter that Works with RTM? | Vista hardware & devices | |||
