Vista - How do I get dialup idle timeout to work with incoming network pro
Old 10-04-2007   #1 (permalink)
yyj
My problem is that the idle disconnect feature does not work for me under
Vista Premium.
I get traffic every so often from the internet, and that seems to reset the
timeout.
If I go into the "network connections folder" -> "properties" on my
modem connection -> "options tab" ... I can see a box labeled "idle
threshold" but it is greyed out.
Ideally I would like to find a idle timeout that is after the firewall has
processed the traffic, so that external traffic that is blocked would not be
counted.
or
I would like to know what I need to do to un-grey that box and then be able
to set the threshold higher.
Ideas please.
Other Information:
My idle timeout is set to 5 minutes.
Watching the status of the connection for 10 minutes, I see nothing
outgoing, about 5000 bytes incoming.
I am using an external USRobotics 56K model 325686-03 modem connected to a
serial port.
I have current drivers for the modem from USR, and current firmware in it.
I am using this older modem because it can retain a connection for a longer
time than an newer internal one when doing a long download. Of course then, I
have the problem of getting it to disconnect <smile>
I have tried setting the timeout in Internet Explorer to the same value.
VSS idle timeout. shadow copy does not work. Vista file management
Task Scheduler > Start On Idle Won't Work Vista General
dialup modem needs to be uninstalled then reinstall to work at reboots. Vista General
dialup modem idle timeout does not work Vista General
Connecting to an existing dialup network Vista General
