When I installed Vista U, I did not do the 'upgrade' path to save any
settings, files, etc; they called it a clean install but of course it was
done on the same drive that had the previous OS. Afterwards, once I
determined that all was well, I deleted the old computer stuff after copying
music, pictures, etc. But all apps were installed from new downloads or CDs.
Don't think I'm gonna do that again just to solve this RDC problem since
everything else seems to be working flawlessly. I only use it for music,
movies, and occasional TV recording, so there aren't many apps on it and not
a lot of churn. I drive a front projector with it at 1080p, so I can't use
another local monitor but rely on RDC to do maintenance, rips, etc. There
must be some simple setting that I haven't found yet that will fix this
problem, so I'll keep looking. I am pretty sure that Vista found a new
network adapter driver when it did the windows update scans and I loaded it,
so if the problem persists, I may drop back to the driver that came with the
mobo CD to see if that helps.
!Al, thanks very much for the attention and suggestions!
Grandan
"Sooner Al [MVP]" wrote:
> "Grandan" <Grandan@xxxxxx> wrote in message
> news:8D43F532-0873-42A4-B0D9-4C4BE2C178C7@xxxxxx
> > I'm no expert at analyzing the event log but here are events that could be
> > related. These are Warning level events:
> > A. Event 4001 (7 occurences in last 24h) WLAN AutoConfig service has
> > successfully stopped.
> > B. Event 4226 (2 occurences in last 24h) TCP/IP has reached the security
> > limit imposed on the number of concurrent TCP connect attempts.
> > Network Location Awareness Service is Started/Auto
> > Dependencies:
> > 1. Network Store Interface Service is Started/Auto
> > ........NSI Proxy Service (I cannot find this in list of services in comp
> > mgmt)
> > 2. Remote Procedure Call Service is Started/Auto
> > ........DCOM Service Process Launcher is Started/Auto
> > 3. TCP/IP Protocol Driver (I cannot find this in list of services in comp
> > mgmt)
> > Is there any intel in this data?
> > Grandan
> > > Not to me...
> Does Network Discovery go away in any other case?
> This may be a legacy of an upgrade versus a clean install. I hate to say
> this but your best recourse may be to blow away the OS and start over fresh.
> Al Jarvi (MS-MVP Windows Networking)
> Please post *ALL* questions and replies to the news group for the
> mutual benefit of all of us...
> The MS-MVP Program - http://mvp.support.microsoft.com
> This posting is provided "AS IS" with no warranties, and confers no
> rights...
> How to ask a question
> http://support.microsoft.com/KB/555375
