Vista - IT or network experts -very strange start up problem, real challen
Old 10-11-2007   #1 (permalink)
superbully
those working with PC's and networks have you ever heard of a problem like
this, it's a real strange one:
If I startup the PC with the ethernet cable into the onboard (gigabyte)
network card then vista will hang when those little bars are going across the
screen (Isn't that the stage where the OS is loading up drivers and things?).
it will do this all day long with the cable plugged in. To get the OS to boot
I have to remove cable, switch off PC at the power supply and also unplug.
Then when i restart it will work fine.
May be worth mentioning that the cable is coming from a D link DI 624
wireless router, although as said, i'm using a cable from said router. I've
checked as much as I know about on the router config screen. MAC address
filtering is disbled, besides I cloned my network cards MAC address to the
router already (thought router may still be looking for the network card on
my old PC). I've run the wizard too, rebooted the router.
Not sure what I've missed It didn't have any problems supplying my XP pro
PC with connection!
If I leave out the router of my network setup altogether and just plug the
internet cable from my ISP's cable modem direct to the PC's network card then
it will startup no problem, over and over.
Another thing worth mentioning is that if i start up the PC without the
internet cable plugged in and the OS is running and THEN i plug in the cable
coming from the router then i will have connection! However on restarting or
shutting down and restarting later whether the cable is in or out of the
network cable port, then it will block again. it's as if it remember that the
router was plugged in before and won't start again!
Am I being dumb and missing a setting in Vista somewhere because i'm not
used to it? Or the router maybe? I could set it up OK for my XP pro PC but
maybe vista is different network wise?
I just don't get it though, how could a setting or router stop a whole OS
from booting up? OK, I can see maybe how I may have connection problem due to
router or vista settings, but to stop a whole OS starting up? WTF.
Really getting on my tats now
Old 10-11-2007   #2 (permalink)
Robert L \(MS-MVP\)
Re: IT or network experts -very strange start up problem, real challen
The DI 624 may not be able to use 1GB. You may try to re-configure the NIC
speed before connecting. This search result may help too.
Connectivity issuesCan't ping another computer because of the ICF Disconnect
from the network while process Access data NIC speed can't go up to 100MB
NIC status displays send ...
www.chicagotech.net/connectivity2.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"superbully" <superbully@xxxxxx> wrote in message
news:BD71EABB-403B-4385-9C3B-3EC3E990FE6F@xxxxxx
> the
> things?).
> boot
> I've
> on
> PC with connection!
> then
> cable
> or
> the
> to
Old 10-11-2007   #3 (permalink)
superbully
sorry for the confusion, that's my fault. I didn't mean i've set the speed to
1GB.
GigaBIT is the name of my NIC. actually it's full name is Atheros L1 Gigabit
ethernet 10/100/1000
would you like me to post ipconfig/all details or i also have a screen
"snip" of the network and sharing screen. although i'm not sure how safe that
is i don't want umpteen hack attempts after posting them LOL
As if by coincidence I have seen in my "problem and sharing" screen that
there is a problem with the NIC and there is a solution for it. However if i
try to proceed and agree to the solution then i get the message that the
microsoft servers are either busy or i have no connection. it's been like
that since yesterday and i do have connection...
Old 10-11-2007   #4 (permalink)
Robert L \(MS-MVP\)
If Gigabit Ethernet is 10/100/1000, the auto speed may not work. I would try
to setup the speed manually.
news:631ADCA0-3677-45F1-AA56-FDB1AF6C16CB@xxxxxx
> to
> 1GB.
> Gigabit
> that
> i
>> NIC
>> Disconnect
Old 10-12-2007   #5 (permalink)
superbully
NIC is not on auto, it's set to 100 half duplex
> > to
> > 1GB.
> > Gigabit
> > that
> > i
> >> NIC
> >> Disconnect
Old 10-22-2007   #6 (permalink)
marika
On Oct 11, 11:51 am, "Robert L \(MS-MVP\)" <nore...@xxxxxx>
Sure hope this works. I will certainly let you know if my wish does
come true.
mk5000
" Forty Shades Of Blue is a complex love story focusing on a lonely
Russian woman who lives with an ageing blues-music legend in Memphis.
When his son comes to visit she is moved by how different he is to his
aggressive and loud father, and we witness the inevitable, slow
movement of the characters falling for each other."--http://
www.kultureflash.net/archive/170/default.htm
Vista Start Problem (Bit Strange) General Discussion
Re: Strange XP-Vista network problem Vista networking & sharing
Strange dialog box - a real mystery Vista General
Strange Network Problem Vista networking & sharing
Strange network problem - Can't save in Office2007 on network driv Vista networking & sharing
