Vista Premium Networking Problems after Sleep, Hibernation
  1. #1
    Frederick Smith Guest
    http://support.microsoft.com/kb/933872 This article describe a little of
    what I have been experiencing. I have my Vista laptop connected to my
    Netgear WGR614v7 router via ethernet cable, NOT wireless.
    When the laptop comes out of Sleep or Hibernation modes it loses the IP and
    other networking info and can not reconnect automatically. Two things
    correct this: 1. Power cycling the router 2. Using the IPCONFIG /RENEW. I
    swapped my WGR614v6 for the WGR614v7, no change.
    Is anyone else seeing this? And, the updates available in the article above
    do not include help for Vista 32-bit. I tried both and they don't install on
    the 32-bit platform. Is Microsoft going to issue something else for Vista
    Premium 32-bit?
    Thanks,
    Fred
  2. #2
    Hoque - Dhaka Guest
    RE: Vista Premium Networking Problems after Sleep, Hibernation
    Question:
    Hi Dear,
    I have setup networking in a new HP laptop with Windows Vista Home Premium
    and found network is working fine showing all the pc in the workgroup and
    able to access them also. I have also create a dummy user in my server
    (windows 2000) and as well as in laptop and avail to logon server with out
    any problem. But I have face problem when I have take the same to the factory
    where this will be finally use. I have change the workgroup according and
    create the user but it does not show all pc in the workgroup and not able to
    logon/access the server (Windows 2000). And networking showing as Network2.
    If I get back In the office and change the workgroup it works fine.
    Please advice how I change the workgroup in the factory to access the
    network including server with out reinstall the OS.
    Thanks in Advance for Help and support.
    Nazmul Hoque
    "Frederick Smith" wrote:
    > Hi,
    > Premium 32-bit?
    > Thanks,
    > Fred
  3. #3
    Robert L \(MS-MVP\) Guest
    Re: Vista Premium Networking Problems after Sleep, Hibernation
    Is the default gateway is 0.0.0.0? Or post the result of ipconfig /all here.
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "Frederick Smith" <fredcsmith@xxxxxx> wrote in message
    news:%23XDerF4DIHA.4476@xxxxxx
    > Hi,
    > and other networking info and can not reconnect automatically. Two things
    > above do not include help for Vista 32-bit. I tried both and they don't
    > install on the 32-bit platform. Is Microsoft going to issue something else
    > for Vista Premium 32-bit?
    > Thanks,
    > Fred
Vista Premium Networking Problems after Sleep, Hibernation problems?
Vista Premium Networking Problems after Sleep, Hibernation 2nd Post Frederick Smith Vista networking & sharing 32 19 Oct 2007
Vista Premium Networking Problems after Sleep, Hibernation Frederick Smith Vista networking & sharing 0 17 Oct 2007
MS Vista Home Premium: Sleep mode problems lemitt@gmail.com Vista networking & sharing 0 10 Jun 2007
Auto-sleep and hibernation problems jilabob Vista General 1 30 Apr 2007
Serious sleep and hibernation problems ~^_^~ Vista General 2 21 Feb 2007
