| Guest | can not connect to a network printer brother laser printer even though it works fine on the network from windows xp computers, the vista laptops can not connect....it says "windows cannot connect to the printer. Access is denied." Vista laptops do recognize the printer....but thats it. thanks...Evan |
| Guest | RE: can not connect to a network printer brother laser printer http://technet.microsoft.com/en-us/l.../bb727037.aspx Helpful link for you. "evanbee" wrote: Quote: > even though it works fine on the network from windows xp computers, the vista > laptops can not connect....it says "windows cannot connect to the printer. > Access is denied." Vista laptops do recognize the printer....but thats it. > thanks...Evan |
| Connect to Network for Printer | Vista installation & setup | |||
| BSOD from Outpost Firewall or Brother network printer? | Vista General | |||
| Can't connect to networked Brother printer | Vista print fax & scan | |||
| HP 1100 Laser Jet Printer and MS Wilrless Laser 600 | Vista hardware & devices | |||
| samsung ml-1710 laser, install network printer, 'workaround' | Vista hardware & devices | |||
