Vista Premium Networking Problems after Sleep, Hibernation 2nd Post
  1. #11
    Frederick Smith Guest
    Re: Vista Premium Networking Problems after Sleep, Hibernation
    NetGear was no help. They said the article did not apply to this router:
    WGR614v7.
    Fred
    "Frederick Smith" <fredcsmith@xxxxxx> wrote in message
    news:%23wSZ0hQEIHA.4956@xxxxxx
    > Thanks Barb,
    > I performed steps 1-7 under RESOLUTION and rebooted. No change. However, I
    > forgot to report one behaviour. After sleep or hibernation mode,
    > [sometimes]Vista appears to be connected [router and internet], browsing
    > works, etc. BUT, the connection is lost after a minute or so. Very strange
    > as this is not the case after sleep or hibernation. Does this clarify
    > anything for you?
    > Again, I only performed steps 1-7, not those following under the MORE
    > INFORMATION section. I am going to call NetGear and point out this article
    > to them and see if they can help. In the meantime, do you have anything
    > else to add?
    > Fred
    > "Barb Bowman" <barb@xxxxxx> wrote in message
    > news:fhich3tstct8krbkglincviq7btbpe1cvr@xxxxxx
    >> Hmmn, take a look at
    >> http://support.microsoft.com/default...b/928233/en-us if you
    >> haven't already.
    >> On Wed, 17 Oct 2007 13:15:04 -0400, "Frederick Smith"
    >> <fredcsmith@xxxxxx> wrote:
    >>>The laptop is an HP dv6406nr. I added 2 gigs of memory, otherwise
    >>>hardware
    >>>is as listed. Vista pre-installed. I use static IP addressing until I can
    >>>resolve the problem. This will explain the ipconfig /all that follows:
    >>>Microsoft Windows [Version 6.0.6000]
    >>>Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    >>>C:\Windows\system32>ipconfig /all
    >>>Windows IP Configuration
    >>> Host Name . . . . . . . . . . . . : Laptop-PC
    >>> Primary Dns Suffix . . . . . . . :
    >>> Node Type . . . . . . . . . . . . : Hybrid
    >>> IP Routing Enabled. . . . . . . . : No
    >>> WINS Proxy Enabled. . . . . . . . : No
    >>>Wireless LAN adapter Wireless Network Connection:
    >>> Media State . . . . . . . . . . . : Media disconnected
    >>> Connection-specific DNS Suffix . :
    >>> Description . . . . . . . . . . . : Broadcom 802.11b/g WLAN
    >>> Physical Address. . . . . . . . . : 00-1A-73-70-CC-AF
    >>> DHCP Enabled. . . . . . . . . . . : Yes
    >>> Autoconfiguration Enabled . . . . : Yes
    >>>Ethernet adapter Local Area Connection:
    >>> Description . . . . . . . . . . . : NVIDIA nForce Networking
    >>> Controller
    >>> Physical Address. . . . . . . . . : 00-1B-24-65-4A-8A
    >>> DHCP Enabled. . . . . . . . . . . : No
    >>> Link-local IPv6 Address . . . . . :
    >>>fe80::8ca7:6e60:47f3:81ec%7(Preferred)
    >>> IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
    >>> Subnet Mask . . . . . . . . . . . : 255.255.255.0
    >>> Default Gateway . . . . . . . . . : 192.168.1.1
    >>> DNS Servers . . . . . . . . . . . : 4.2.2.2
    >>> 4.2.2.1
    >>> NetBIOS over Tcpip. . . . . . . . : Enabled
    >>>Tunnel adapter Local Area Connection* 9:
    >>> Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    >>> Physical Address. . . . . . . . . : 02-00-54-55-4E-01
    >>> IPv6 Address. . . . . . . . . . . :
    >>>2001:0:4136:e38e:20b8:2dce:3f57:fefd(Pref
    >>>erred)
    >>>fe80::20b8:2dce:3f57:fefd%8(Preferred)
    >>> Default Gateway . . . . . . . . . : ::
    >>> NetBIOS over Tcpip. . . . . . . . : Disabled
    >>>Tunnel adapter Local Area Connection*:
    >>>isatap.{DDC4E2EB-7106-4D74-8EBB-AE2DC8EA4
    >>>82F}
    >>> Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    >>> fe80::5efe:192.168.1.2%12(Preferred)
    >>> 4.2.2.1
    >>>Tunnel adapter Local Area Connection* 2:
    >>>isatap.{7F126FAC-5E91-4D09-A8B1-359AFDDF8
    >>>BFB}
    >>>** End **
    >>>Fred
    >>>news:u7gch35vf2n02evtkug98eh8lbmopida66@xxxxxx
    >>>> Which exact laptop do you have? Did it come with Vista pre-installed
    >>>> or was this an upgrade?
    >>>> Can you please post the text output of
    >>>> ipconfig /all
    >>>> run from an elevated cmd prompt?
    >>>> On Wed, 17 Oct 2007 12:08:46 -0400, "Frederick Smith"
    >>>>>The KB article did not solve the problem. I have the latest driver for
    >>>>>my
    >>>>>Nvidia Gforce networking card. I have installed all windows updates. I
    >>>>>leave
    >>>>>the router and modem on 24/7.
    >>>> Barb Bowman
    >>>> MS Windows-MVP
    >>>> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
    >>>> http://blogs.digitalmediaphile.com/barb/
    >> Barb Bowman
    >> MS Windows-MVP
  2. #12
    Robert L \(MS-MVP\) Guest
    Re: Vista Premium Networking Problems after Sleep, Hibernation 2nd Post
    Is the default gateway 0.0.0.0? Or post back with the result of ipconfig
    /all.
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    news:eyBEAhNEIHA.4400@xxxxxx
    > Hi,
    > I have installed all MS updates available through Windows update. I used
    > the
    > link below and installed update #1 on the list, KB929777, "Install this
    > update to address an issue in storport.sys which results in a system crash
    > when certain hardware configurations exist."
    > I did not fix the problem[no change].
    > Fred
    > "Robert L (MS-MVP)" <noreply@xxxxxx> wrote in message
    > news:%23ydfD%23GEIHA.4228@xxxxxx
    >> Have you tried Microsoft update? This link may help.
    >> Windows Vista Update and downloadThis update may fix some DHCP issue -
    >> The default gateway setting is lost when you wake a Windows Vista-based
    >> computer from sleep ...
    >> http://www.chicagotech.net/netforums...7429cccc3f07ce
    >> news:%23A7O8iEEIHA.4772@xxxxxx
    >>> Hi,
    >>> Is there not a MS MVP who can help me with this? I have a HP laptop and
    >>> HP can not help any further. They say it's a MS problem, but my laptop
    >>> does not qualify for MS Tech Support because its OEM, HP.
    >>> http://support.microsoft.com/kb/933872 This article describe a little of
    >>> what I have been experiencing. I have my Vista laptop connected to my
    >>> Netgear WGR614v7 router via ethernet cable, NOT wireless.
    >>> When the laptop comes out of Sleep or Hibernation modes it loses the IP
    >>> and
    >>> other networking info and can not reconnect automatically. Two things
    >>> correct this: 1. Power cycling the router 2. Using the IPCONFIG /RENEW.
    >>> I
    >>> swapped my WGR614v6 for the WGR614v7, no change.
    >>> Is anyone else seeing this? And, the updates available in the article
    >>> above
    >>> do not include help for Vista 32-bit. I tried both and they don't
    >>> install on
    >>> the 32-bit platform. Is Microsoft going to issue something else for
    >>> Vista
    >>> Premium 32-bit?
    >>> Thanks,
    >>> Fred
  3. #13
    Barb Bowman Guest
    can you post the text output of
    ipconfig /all from an elevated cmd prompt when the computer is in
    the "bad" state?
    On Wed, 17 Oct 2007 17:55:20 -0400, "Frederick Smith"
    >Thanks Barb,
    >anything for you?
    >to them and see if they can help. In the meantime, do you have anything else
    >to add?
    >Fred
    >> haven't already.
    >>>The laptop is an HP dv6406nr. I added 2 gigs of memory, otherwise hardware
    >>> Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
    >>> 4.2.2.1
    >>>erred)
    >>>82F}
    >>> 4.2.2.1
    >>>BFB}
    >>>** End **
    >>>Fred
    >>>> ipconfig /all
    >>>>>my
    >>>>>leave
    >>>> Barb Bowman
    >>>> MS Windows-MVP
    >> Barb Bowman
    >> MS Windows-MVP
    Barb Bowman
    MS Windows-MVP
  4. #14
    Dwarf Guest
    RE: Vista Premium Networking Problems after Sleep, Hibernation 2nd Pos
    Hi Frederick,
    Do you have a static or dynamic IP address? By static I mean one that you
    use permanently and by dynamic one that your ISP assigns to you for the
    session. If it is dynamic, then this could explain your problem. Most dynamic
    addresses are issued on a time-lease basis, and if your ISP doesn't receive a
    reply from your machine after a certain period of time (as is the case when
    you put your machine to sleep or hibernate), then it will assume that the
    address is free and will unallocate it from your connection and reallocate it
    to someone else. If ISPs didn't do this, then there would soon be no
    addresses available for future customers. I recommend that home users use a
    dynamic address because this is much cheaper than having a static one. Static
    addresses are useful for companies whose address on the Web must not change,
    however their ISP will charge them for the privilege. I also use the
    hibernate function on my machine and have a Netgear router, but because I
    power off completely both my machine and router after hibernating, I don't
    have this problem. You will probably be better off just using the hibernation
    feature rather than sleep if you are running your machine on battery power.
    In fact, I would recommend that you didn't use sleep at all. You should find
    that in the short time that it takes your machine to restore from hibernation
    (typically no more than 1 1/2 minutes), your router will have established a
    connection for you. This is why I recommend that you power down your router
    as well when you hibernate.
    Dwarf
    "Frederick Smith" wrote:
    > Hi,
    > Is there not a MS MVP who can help me with this? I have a HP laptop and HP
    > can not help any further. They say it's a MS problem, but my laptop does not
    > When the laptop comes out of Sleep or Hibernation modes it loses the IP and
    > correct this: 1. Power cycling the router 2. Using the IPCONFIG /RENEW. I
    > Is anyone else seeing this? And, the updates available in the article above
    > do not include help for Vista 32-bit. I tried both and they don't install on
    > the 32-bit platform. Is Microsoft going to issue something else for Vista
    > Premium 32-bit?
    > Thanks,
    > Fred
  5. #15
    Thanks Barb,
    Keep in mind that when the laptop exits sleep mode it is connected to the
    internet and then disconnects after about a minute or so.
    Here is the ipconfig /all [after disconnect]:
    Autoconfiguration IPv4 Address. . : 169.254.129.236(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    DHCPv6 IAID . . . . . . . . . . . : 184556324
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    82F}
    fe80::5efe:169.254.129.236%12(Preferred)
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    BFB}
    ** End **
    Fred
    news:r28eh3p4tucvdnlmhj2uek7a9q5486kepd@xxxxxx
    > the "bad" state?
    >>Thanks Barb,
    >>anything for you?
    >>else
    >>to add?
    >>Fred
    >>> haven't already.
    >>>>hardware
    >>>>can
    >>>> Controller
    >>>> 4.2.2.1
    >>>>erred)
    >>>>82F}
    >>>> 4.2.2.1
    >>>>BFB}
    >>>>** End **
    >>>>Fred
    >>>>> ipconfig /all
    >>>>>>my
    >>>>>>leave
    >>>>> Barb Bowman
    >>>>> MS Windows-MVP
    >>> Barb Bowman
    >>> MS Windows-MVP
    > Barb Bowman
    > MS Windows-MVP
  6. #16
    Thanks Robert,
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    82F}
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    BFB}
    ** End **
    Fred
    news:%23MmVd$TEIHA.6120@xxxxxx
    > /all.
    >> Hi,
    >> the
    >> crash
    >> Fred
    >>>> Hi,
    >>>> of
    >>>> and
    >>>> I
    >>>> above
    >>>> install on
    >>>> Vista
    >>>> Premium 32-bit?
    >>>> Thanks,
    >>>> Fred
  7. #17
    Thanks Dwarf,
    I have the same issue after sleep or hibernation. After the Vista wakes, the
    internet connection shows connected, but then disconnects after about a
    minute or so.
    I am using a static IP for the moment until I can figure out the problem.
    Fred
    "Dwarf" <Dwarf@xxxxxx> wrote in message
    news767C470-7DE5-44D1-94FC-1BB684F0C0C1@xxxxxx
    > Hi Frederick,
    > dynamic
    > receive a
    > when
    > it
    > a
    > Static
    > change,
    > hibernation
    > power.
    > find
    > hibernation
    > a
    > router
    > Dwarf
    >> Hi,
    >> HP
    >> not
    >> and
    >> above
    >> on
    >> Premium 32-bit?
    >> Thanks,
    >> Fred
  8. #18
    Barb Bowman Guest
    Can you
    1: disable the wireless adapter in device manager for now
    2: unbind IPv6 from the wired connection
    reboot
    any better?
    On Thu, 18 Oct 2007 12:05:29 -0400, "Frederick Smith"
    >Thanks Barb,
    > fec0:0:0:ffff::2%1
    > fec0:0:0:ffff::3%1
    >82F}
    > fec0:0:0:ffff::2%1
    > fec0:0:0:ffff::3%1
    >BFB}
    >** End **
    >Fred
    >> the "bad" state?
    >>>Thanks Barb,
    >>>anything for you?
    >>>else
    >>>to add?
    >>>Fred
    >>>> haven't already.
    >>>>>hardware
    >>>>>can
    >>>>> Controller
    >>>>> 4.2.2.1
    >>>>>erred)
    >>>>>82F}
    >>>>> 4.2.2.1
    >>>>>BFB}
    >>>>>** End **
    >>>>>Fred
    >>>>>> ipconfig /all
    >>>>>>>my
    >>>>>>>leave
    >>>>>> Barb Bowman
    >>>>>> MS Windows-MVP
    >>>> Barb Bowman
    >>>> MS Windows-MVP
    >> Barb Bowman
    >> MS Windows-MVP
    Barb Bowman
    MS Windows-MVP
  9. #19
    Thanks Barb,
    I disabled wireless, unchecked IPv6 from Local Area Connection Properties,
    Fred
    PS If I shelled out the $59 or whatever the cost for a per-incident
    telephone call to MS do you think they might be able to help? I'm getting
    discouraged here.
    news:el2fh31qb0slj0ldrpiiv075a24rsa60i2@xxxxxx
    > Can you
    > reboot
    > any better?
    >>Thanks Barb,
    >> fec0:0:0:ffff::2%1
    >> fec0:0:0:ffff::3%1
    >>82F}
    >> fec0:0:0:ffff::2%1
    >> fec0:0:0:ffff::3%1
    >>BFB}
    >>** End **
    >>Fred
    >>> the "bad" state?
    >>>>Thanks Barb,
    >>>>I
    >>>>strange
    >>>>anything for you?
    >>>>article
    >>>>else
    >>>>to add?
    >>>>Fred
    >>>>> haven't already.
    >>>>>>hardware
    >>>>>>can
    >>>>>> Controller
    >>>>>> 4.2.2.1
    >>>>>> Pseudo-Interface
    >>>>>>erred)
    >>>>>>82F}
    >>>>>> 4.2.2.1
    >>>>>>BFB}
    >>>>>>** End **
    >>>>>>Fred
    >>>>>>> ipconfig /all
    >>>>>>>>for
    >>>>>>>>my
    >>>>>>>>I
    >>>>>>>>leave
    >>>>>>> Barb Bowman
    >>>>>>> MS Windows-MVP
    >>>>> Barb Bowman
    >>>>> MS Windows-MVP
    >>> Barb Bowman
    >>> MS Windows-MVP
    > Barb Bowman
    > MS Windows-MVP
  10. #20
    Robert,
    I mentioned this article, http://support.microsoft.com/kb/933872, when in my
    first post. But, it does not seem to apply to the 32-bit Vista. Or, am I
    wrong about this?
    Fred
    > /all.
    >> Hi,
    >> the
    >> crash
    >> Fred
    >>>> Hi,
    >>>> of
    >>>> and
    >>>> I
    >>>> above
    >>>> install on
    >>>> Vista
    >>>> Premium 32-bit?
    >>>> Thanks,
    >>>> Fred
Page 2 of 4 FirstFirst 1234 LastLast
Vista Premium Networking Problems after Sleep, Hibernation 2nd Post problems?
Solved Post sleep/hibernation status is not normal coolnewyorker General Discussion 5 25 Nov 2008
Vista Premium Networking Problems after Sleep, Hibernation Frederick Smith Vista networking & sharing 2 17 Oct 2007
Vista Premium Networking Problems after Sleep, Hibernation Frederick Smith Vista networking & sharing 0 17 Oct 2007
Auto-sleep and hibernation problems jilabob Vista General 1 30 Apr 2007
Serious sleep and hibernation problems ~^_^~ Vista General 2 21 Feb 2007
