Connecting to wireless network - EAP properties return error
  1.    17 Oct 2007 #1
    Jitse Guest
    Good day,
    I'm trying to connect to the wireless network of my university, but I keep
    getting the same error. I did everything correct, but when I want to apply
    the certificate to the connection, I get an error.
    What I do is this: I go the the network centre, choose "Manage Wireless
    Networks". Then I right-click the wireless network, and choose properties.
    Then I go to the "Security" tab. When you look at the "method of network
    verification" listbox, "Protected EAP (PEAP)" is chosen (which is correct).
    Next to the listbox I click "Configuration..." (so I can select the correct
    certificate). But I simply get an error when I press that configuration
    button.
    This is the error:
    Windows has encountered an error saving the EAP properties. Specific
    error: The specified module could not be found.
    Maybe my description is a little vague, here's a clear screenshot:
    http://www.geocities.com/xargotheone/offsite/error.jpg
    Thanks in advance.
  2.    18 Oct 2007 #2
    Mick Murphy Guest
    RE: Connecting to wireless network - EAP properties return error
    http://www.microsoft.com/technet/com...uy/cg0406.mspx
    The above link is for wireless networking.
    I think you are complicating it!!!
    "Jitse" wrote:
    > Good day,
    > button.
    > This is the error:
    > Thanks in advance.
  3.    18 Oct 2007 #3
    Jitse Guest
    I'm certainly not. I did exactly what's written in that article you've given
    me. Except from one thing, because it's simply not possible because I get
    that error. It's at this point:
    (image of the article)
    http://img.microsoft.com/library/med...y/cg040606.gif
    (my own screenshot)
    I've got as options:
    Security Type: 802.1x
    Encryption Type: WEP
    Network Authentication Method: Protected EAP (PEAP)
    All I have to do now, is click that "Settings..." button and select the
    correct certificate. But when I click that button I get that error (as you
    can see in my own screenshot or read in the starting post of this topic).
    Could anyone help me with this please?
  4.    18 Oct 2007 #4
    Jeffrey Randow Guest
    Re: Connecting to wireless network - EAP properties return error
    Try using TLS if you are doing Cert Based 8021x...
    Jeffrey Randow
    jeffreycentex@xxxxxx
    Windows Networking MVP 2001-2006
    http://www.networkblog.net
    On Thu, 18 Oct 2007 09:01:01 -0700, Jitse
    >(my own screenshot)
  5.    19 Oct 2007 #5
    Jitse Guest
    Do you mean the "SecureW2 TTLS"? I tried that, then I get about the same error:
    error: Unspecified error.
    > Jeffrey Randow
    > >(my own screenshot)
  6.    19 Oct 2007 #6
    Jitse Guest
    Alright nevermind, I found the problem. It's this stupid SecureW2 third-party
    program that's supposed to help you with setting up a wireless connection,
    hehehe. It was even recommended by the technical notes of the server I wanted
    to connect to. It's probably just a Vista 64bit incompatibility.
    Thanks for the replies though.
  7.    25 Oct 2007 #7
    ivo.a.l.vieira Guest
    Can you tell me what you have done to fix it?
    I have exacly the same problem that you had. I'm a student of IST, I
    have Vista Ultimate 64bit and I also need SecureW2.
    Please help me.
    Greetings
    Ivo Vieira
  8.    21 Nov 2007 #8
    vista ultimate x64
    Local Time: 11:16
    so what's the catch?
How do I keep wireless network from automatically connecting?
I'm new to both the wireless thing and to Vista, so bear with me (I'm helping a friend set up her new laptop). Basically, I want to force a...
Vista General
Sharing tab is missing on Wireless network connection properties
Hi, I am trying to get my Xbox360 to share internet with my laptop. However when I want to alow the connection and I go to network sharing center,...
Vista General
Connecting to a wireless network
I have a pc which has a wireless network enabled. There is an existing laptop which accesses this network. I have purchased an additional laptop and...
Vista networking & sharing
connecting to a wireless network
hi i have a wireless router set up which is connected with a wire to my PC. my brother has just brought a brand new laptop. he has full signal to...
Error connecting to a wireless network with disabled SSID
Hi! Can anyone tell me if there are problem to access a wireless network with SSID disabled. The opsystem is Windows Vista. In my Windows XP system...
RE: Problem connecting to wireless network
"peccrn" wrote I recently purchased a new toshiba laptop with vista home bascic. My wireless internet connection was working fine for the first...
Wireless network not connecting
I bought a brand new Toshiba Satellite A135-s2276 with Atheros AR5006x wireless network adapter. The system only connects to about 50% of the...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
