| Windows Vista x64 | Internet problem,please help! Hello,I reinstalled my Windows and now I'm with Vista x64 (I was with XP x86 before).My internet works fine (as you can see ),but I have one problem.I cannot open 2 internet sites.Only 2,but really important for me.The sites are working,I'm not banned or something,just when I type the address and hit "Enter" it starts loading and then I get this "The connection has timed out".I'm using Mozilla Firefox,but the same thing happens with IE.What can it be?What can be causing this?It's really bad,because if I don't get it fixed somehow I have to go back to XP So,please if you can help me I'll really apreceate it.Thanks. |
| | Re: Internet problem,please help! If that only happens on Vista computer, you may want to check the firmware. This link may help too. Vista Internet Access IssuesVista Internet access issues. Dropping Internet Connection ... Vista: Can't access some secure web sites ... don't fix the problem, try to use FireFox ... www.chicagotech.net/vista/vistaieissues.htm -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Georgiev" <Georgiev.2yn3zf@xxxxxx-mx.forums.net> wrote in message news:Georgiev.2yn3zf@xxxxxx-mx.forums.net... Quote: > > Hello,I reinstalled my Windows and now I'm with Vista x64 (I was with XP > x86 before).My internet works fine (as you can see ),but I have one> problem.I cannot open 2 internet sites.Only 2,but really important for > me.The sites are working,I'm not banned or something,just when I type > the address and hit "Enter" it starts loading and then I get this "The > connection has timed out".I'm using Mozilla Firefox,but the same thing > happens with IE.What can it be?What can be causing this?It's really > bad,because if I don't get it fixed somehow I have to go back to XP > So,please if you can help me I'll really apreceate it.Thanks.> > > -- > Georgiev |
| Windows Vista x64 | Re: Internet problem,please help! Check the firmware...what do you mean?I have Automatic Updates On. |
| Internet Problem | Vista performance & maintenance | |||
| Internet Explorer Problem *HELP* Maybe a Javascript problem | Browsers & Mail | |||
| Internet problem. | Network & Sharing | |||
| Internet problem | Vista networking & sharing | |||
| Internet/High Speed Internet Problem | Vista networking & sharing | |||
