| | System Configuration changes cause Vista to not reboot While trying to get Vista to run chkdsk on startup, I made the following changes to System Configuration: - Diagnostic Startup - No GUI Boot My laptop now starts up, shows the "filmy green curtain" backdrop, displays the words "Windows Vista Starting Up" (or something like that) in Courier typeface, and then hangs. Is there a way to get Vista to start up again? It came on the laptop, without a backup disk. Thanks, Peter |
| | Re: System Configuration changes cause Vista to not reboot Hi, Do you get to a command line? Alternately, have you tried hitting F8 at boot and selecting safe mode from the menu? Or try the last known good configuration? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "pc_trott" <pc_trott@xxxxxx> wrote in message news:E95FAEEE-9755-4830-87C2-B2ACF7FE218E@xxxxxx Quote: > While trying to get Vista to run chkdsk on startup, I made the following > changes to System Configuration: > - Diagnostic Startup > - No GUI Boot > > My laptop now starts up, shows the "filmy green curtain" backdrop, > displays > the words "Windows Vista Starting Up" (or something like that) in Courier > typeface, and then hangs. > > Is there a way to get Vista to start up again? It came on the laptop, > without a backup disk. > > Thanks, > Peter |
| System Configuration keeps starting up with Windows Vista | Vista General | |||
| System Stuck in Loop on Both Reboot and System Restore | Vista General | |||
| dual operating system in a raid 0 configuration xp/vista | Vista installation & setup | |||
| System configuration utility in Vista Ultimate 32 | Vista performance & maintenance | |||
| WMP Crashed Vista Premium.. System reboot. | Vista music pictures video | |||
