| Guest | Restart problem! After installing the latest Vista updates, my PC will no longer restart unless i turn the power off completly. It just stops at the microsoft load bar screen? Even shutting it down doesn't work, the power must be switched off at the socket, then it will restart. Any ideas? Running Vista Ultimate. |
| Guest | Re: Restart problem! Hi, Uninstall the updates, one at a time, until you know which one caused the issue. Then go here and choose one of the support options for Windows Update and report the issue: http://support.microsoft.com/oas/def...0&gprid=436974 -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Smiffy" <Smiffy@xxxxxx> wrote in message news:4C3847B9-69F0-4F93-99D3-E72CC2EC7BD4@xxxxxx Quote: > After installing the latest Vista updates, my PC will no longer restart > unless i turn the power off completly. It just stops at the microsoft load > bar screen? Even shutting it down doesn't work, the power must be > switched > off at the socket, then it will restart. > Any ideas? > > Running Vista Ultimate. |
| Delayed Restart Problem | Vista General | |||
| Please Help: Vista Restart Problem | General Discussion | |||
| restart problem | General Discussion | |||
| wireless usb problem, must restart | Vista networking & sharing | |||
