Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Rich txt not does not show in iNotes
Old 10-25-2007   #1 (permalink)
Chris
When I reply in iNotes, the rich text does not show. I can only use plain
txt. How do I fix this?
Thanks
Old 10-25-2007   #2 (permalink)
Malke
Re: Rich txt not does not show in iNotes
> Thanks
iNotes is third-party software. Check with their tech support about this
issue.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 10-25-2007   #3 (permalink)
Chris
The problem is regarding Vista - this is not a problem when running XP. I
think it is a securityproblem, but I don't know where that setting is. (I
can't open attachments either).
Chris
"Malke" wrote:
Quote:
> > Thanks
> issue.
> Malke
> "Don't Panic!"
Old 10-25-2007   #4 (permalink)
Malke
No, it is a problem with this particular software running in Vista.
Contact iNotes tech support or look on their website for known issues,
workarounds, patches.
Malke
"Don't Panic!"
Windows Vista isues when using DWA (iNotes) HTML control Vista General
The New Rich Vista file management
Windows Vista, IE7, and iNotes Web Access Vista General
To Rich Vista mail
Lotus inotes (webmail) help please Vista General
