Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - System crashes on a regular basis ??
Old 07-07-2006   #1 (permalink)
=?Utf-8?B?TWlrZQ==?=
My Vista-B2 system crashes on a regular basis.
However... it's not just your everyday BSoD, but it actually blows the
entire OS out of the water and commences a reboot.
If left running overnight, I invariably find the system sitting at a POST
prompt in the morning... telling me that my SATA harddrive is missing from
the BIOS... WTF??
On the occassions when I've been there to witness what happens... the system
seems to start scanning the disk for something... the CPU fan goes
ballistic... the UI becomes totally unresponsive (not even Ctrl+Alt+Del will
get it's attention) and eventually... KaBOOM!!! ...we are now in reboot
In a new twist... this morning the system still had the screen-saver logo
displayed... but the UI was totally unresponsive and the CPU fan was
throttled up for V2... rotate... no idea how long the engine had been
screaming like this, and the only option was index-to-power.
Old 07-10-2006   #2 (permalink)
RE: System crashes on a regular basis ??
Well.. I finally gave up with it, after vista trashed my system... and then
did so again, within hours of re-installing.
XP won't do what I want (develop websites with an addressable IIS website)
so... I've installed Win-2003 server.
Now, I just have to work out how to get my Microsoft keyboard working
again... what the hell do microsoft think they are saving the world from, by
not supporting their own USB-BT radio, and hence making it impossible to use
their own BT desktop.
One very P'd off customer.
> the BIOS... WTF??
Old 07-10-2006   #3 (permalink)
P.S. I will NOT be going back to VISTA... this is quite easily the WORST
Beta-2 that MS have ever released (I was a survivor of the NT3.51->NT4 and
NT4->NT5 debacles)… flaky as all hell and with almost no driver or
application support… I will not put myself through this crap any more.
When MS have an SP2 of the next version… I’ll consider upgrading.
> the BIOS... WTF??
Old 07-10-2006   #4 (permalink)
Mark D. VandenBerg
Re: System crashes on a regular basis ??
Hey, Mike;
Sorry to hear of your troubles. Conversely, there are many people,
Including myself, who are running Vista and are having relatively good
results. In fact, I have not had one BSOD!
Is it possible an incompatible driver is responsible for your woes?
Mark
Keeping the fun in dysfunctional!
"Mike" <Mike@discussions.microsoft.com> wrote in message
news:FB6D1BA9-15D6-42BD-946A-6B6BCEBCF66F@microsoft.com...
>> from
>> the BIOS... WTF??
>> system
>> will
Old 07-10-2006   #5 (permalink)
If it's a driver issue, then is a Microsoft Driver issue... as there was
nothing installed that was not part of vista.
The machine is a HP D530... so it's not as if it's an unstable clone, or a
machine so new that the HW is not supportable... and all the firmware if
fully up-to-date.
Since installing Windows 2003 to replace vista... not even a hint of a hiccup.
I'll be sticking with this now, and giving vista the flick.
"Mark D. VandenBerg" wrote:
> Hey, Mike;
> Mark
> >> from
> >> the BIOS... WTF??
> >> system
> >> will
Old 07-11-2006   #6 (permalink)
R. C. White
Hi, Mike.
Maybe too late to even ask you this, but did you change the default setting
for what to do on System Failure? The default is to Automatically Restart,
putting you back at the POST with no clue as to the underlying problem.
Let's see. I had these steps memorized in WinXP, but in Vista... Press the
Windows key + Pause/Break; this brings up the System window. Then click
Advanced system settings | Advanced | Startup and Recovery / Settings.
Under System failure, remove the check from Automatically restart. Next
time, instead of a POST screen, you should see a BSOD - with codes telling
which driver failed. It won't help much with hardware problems, of course,
but it should tell you if anything in software is causing your problem.
It sounds like you are an experienced user and you probably already thought
of that, but sometimes we overlook the simple stuff.
As Mark said, I like Vista. This latest build (5456) is much better than
what we first saw last summer. There are still bugs, of course, but I'm
optimistic about what we'll see when it finally goes Gold.
RC
R. C. White, CPA [RC]
San Marcos, TX
rc@grandecom.net
Microsoft Windows MVP
(currently running Windows Mail 7 in Vista x64 Build 5456)
news:013A0CB8-0253-408F-A804-462E6FA1E005@microsoft.com...
> fully up-to-date.
> hiccup.
>> Hey, Mike;
>> Mark
>> > WORST
>> > and
>> >> POST
>> >> from
>> >> the BIOS... WTF??
>> >> system
>> >> Ctrl+Alt+Del
>> >> will
>> >> reboot
>> >> logo
Old 07-11-2006   #7 (permalink)
No, I didn’t do that, but to be honest… I don’t see the advantage of a BSoD
over a hard reboot… when the system is not running anything other than what
MS installed… i.e. Why would I want to debug MS’s work for them? my role as a
beta-tester is to debug the stuff they DIDN’T write or can’t test themselves.
I have a Hewlett-Packard workstation (modern, but not the very latest
new-fangled toy) which ran Win-XP perfectly, and is now running Win-2003
perfectly… but which crashed every day running Vista… and eventually
obliterated my system disk.
I fully appreciate the value of beta testing, but to have a system crashing
like this, is not what I call beta-testing… it’s what I call masochism.
You are perfectly correct that MS will eventually sort Vista out… as they
did with NT4 and W2K … but they are DEFINITELY now pushing the schedule on
this **WAY** too fast, in order to satisfy their need for something to sell
(and something for ISV’s to sell off) and hence keep the market speculators
placated.
MS continue to fall for the same old trap, with ALL of their products… avoid
selling minor upgrades, over-specify the next major upgrade and
under-estimate the resources needed to achieve it.
The net result is ALWAYS the same with MS… late delivery, dropped features
and a shipped product full of bugs.
MS need to learn from their own history… and target minor-upgrades, shipped
on a more regular basis.
NT3.51 -> NT4.0 == PAIN
NT4.0 -> NT5.0 == PAIN
NT5.0 -> NT5.1 == NO-PAIN
NT5.0/1 -> NT5.2 == NO-PAIN
NT5.0/1/2 -> NT6.0 == PAIN
You would think that SOMEONE at Microsoft would look at this and figure..
hey, you know what?? We tend to ship major upgrades, rather than minor
upgrades… and every time we ship a major upgrade, we get a whole bunch of
problems and a heap of p’d-off customers… perhaps we should focus on
shipping/selling more minor upgrades and only ship major upgrades when they
are truly ready for prime-time.
Perhaps we could even satisfy that whole "Software Assurance" thing we
suckered people into, if we did that.
"R. C. White" wrote:
> Hi, Mike.
> RC
> San Marcos, TX
> rc@grandecom.net
> > fully up-to-date.
> > hiccup.
> >> Hey, Mike;
> >> Mark
> >> > WORST
> >> > and
> >> >> POST
> >> >> from
> >> >> the BIOS... WTF??
> >> >> system
> >> >> Ctrl+Alt+Del
> >> >> will
> >> >> reboot
> >> >> logo
Old 07-15-2006   #8 (permalink)
=?Utf-8?B?Q1dC?=
I recently started experiencing spontaneous reboots on my 5384-build system,
myself.
I'm not sure what causes it, I'll just be in the middle of something and the
system will just drop into a reboot.
It looks like an update was sent over and installed on the 12th, and that
seems to be about the right timeframe. I wonder if there is something in that
update that is causing the problem.
> the BIOS... WTF??
Old 07-15-2006   #9 (permalink)
R. C. White
Hi, CWB.
Same basic advice that I gave Mike: Remove the check from Automatic restart
on System failure.
Spontaneous reboots can be caused by hardware or by software. The BSOD is
your friend if the fault is in software, because Windows detects that it is
about to reboot and presents the BSOD instead. We non-experts may need some
help in interpreting the codes, but they should hold the clues to what is
causing the problem. New updates might have included a faulty driver or,
especially in a beta like Vista, some new code that is not fully compatible
with the old.
Hardware problems don't generally produce a BSOD. When the power cord is
yanked from the computer, the system has no time to write a log or a BSOD or
anything else. Less drastic hardware problems, like overheating or faulty
cables, also don't usually produce error codes that can be written to a log
or BSOD.
So, if you remove the instruction to Automatically restart and you still
don't get a BSOD, then start looking for a hardware problem. If you do get
a BSOD that you can't figure out, post it here VERBATIM and somebody
probably can tell you where to look next.
RC
San Marcos, TX
rc@grandecom.net
"CWB" <CWB@discussions.microsoft.com> wrote in message
news:68DD9820-9113-46F3-B514-DBA4B3FEB425@microsoft.com...
>system,
> myself.
> the
> that
>> from
>> the BIOS... WTF??
>> system
>> will
Old 07-16-2006   #10 (permalink)
=?Utf-8?B?Q1dC?=
All righty,
I'll try it and see what happens.
> Hi, CWB.
> on System failure.
> with the old.
> or BSOD.
> RC
> San Marcos, TX
> rc@grandecom.net
Nvidia: Windows 7 driver updates to come on a regular basis Vista News
System crashes Vista Games
try DVD and system crashes???? Vista music pictures video
(http?) network goes down on regular basis (Vista 32 Home Premium) Vista General
Do regular backup and/or complete system backup include shadow copies of files? Vista General
