Help
  1. #1
    Manny Guest
    Help
    I'm pretty dumb when it comes to computers and i've been having a problem
    with logging in. I type in my password and it automatically logs off. The
    only way im able to start my laptop is through safe mode. Can anyone help me
    out...Thanks.
  2. #2
    Rick Rogers Guest
    Re: Help
    From Safe mode, run msconfig (using the start/search box) and place the
    system in diagnostic mode. Restart and see if you can log in now. If so,
    then move to selective startup and enable only a few of the items on the
    startup tab, then click apply/ok and restart. See if you can login. Repeat
    until you cannot login. When that occurs, you know you've enabled the item
    that is keeping it from loading normally. Report back with what this item
    is.
    If you cannot login even in diagnostic mode, then you might try running a
    system restore to a point prior to this happening.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    My thoughts http://rick-mvp.blogspot.com
    "Manny" <Manny@xxxxxx> wrote in message
    news:334484F1-57FA-404A-A6F8-A51ED517B68C@xxxxxx
    > me
    > out...Thanks.
Help problems?
