1.    31 Oct 2007 #1
    Gtpod Guest
    Need more help with partitioning!
    Hey guys,
    So I've run some 3rd party defrag tool that sorted out the system files, and
    now Vista's partition program says I can shrink my C: drive by 65GB, all the
    free space on the drive.
    However, when I try to shrink it by 20GB, it shows the following message:
    "An unexpected error has occurred. Check the System Event Log for more
    information on the error. Close the Disk Management console, then restart
    Disk Management or restart the computer."
    I've followed its advice but the problem still stands. I tried checking the
    Event Viewer for more information, but it's very confusing stuff.
    Help is greatly appreciated.
    Cheers.
  2.    01 Nov 2007 #2
    BurrWalnut Guest
    RE: Need more help with partitioning!
    It may help you to shrink partitions by running the diskpart command from the
    Vista DVD, which also avoids the occurrence of locked files.
    "Gtpod" wrote:
    > Hey guys,
    > Cheers.
Partitioning
Hi, I used the Disk Management (Administrative Tools) to Partition a 500G "C" Drive to a C, D, E and F Drive. I decided that I don't need one of...
Vista file management
Partitioning on 64 bit
Would someone please tell me what software can partition using the 64 bit os? Thanks, Mike
Vista performance & maintenance
Partitioning HD
Can partioining be done after installing Vista Home premium?
Vista installation & setup
Need help with partitioning
Hey, I am trying to use the Computer Management tool to partition my main C: drive (160GB), but when I right-click and select shrink, it tells me...
Partitioning
Steve <hde@wbn.inv> schreef in bericht news:c0v883hg5ptgs42l89ajatstutlsj3gts5@4ax.com... > Just setting up a new Vista Home Premium PC. Disk...
Vista General
Partitioning
I am attempting to partition a drive using Vista's Disk Management and can create three volumes, but when I try to create a fourth, it tries to...
Partitioning
I'd like to create a dual-boot for XP and Vista to run on my system. Problem is that even though I have over 40GB of space on my drive, it won't let...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
