| | Battery and Charging I could have my computer plugged in to charge while I am using my computer but it will not charge, however, it will charge when my computer is off. Is there a setting to change this? |
| | Re: Battery and Charging some batteries have a have a safety to stop them charging if they are to hot , try turning on your computer whilst it is charging and see how long before it stops , then check if the battery is hot "Becca" <Becca@xxxxxx> wrote in message news:9FBD60EF-164B-4CCD-983C-6840888B0042@xxxxxx Quote: >I could have my computer plugged in to charge while I am using my computer > but it will not charge, however, it will charge when my computer is off. > Is > there a setting to change this? |
| Battery plugged in, not charging | Vista hardware & devices | |||
| battery plugged in, not charging | Vista hardware & devices | |||
| Charging Battery | Vista hardware & devices | |||
| The battery is new but is not charging | Vista performance & maintenance | |||
| charging battery | Vista performance & maintenance | |||
