Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Problem Reports and Solutions
Old 07-08-2006   #1 (permalink)
=?Utf-8?B?UmFuZHkgSy4=?=
I was wondering if anyone knows how to get the "Problem Reports and
Solutions" to work if it's not? It was working OK and I ran a Optimize
program and I guess it shut it off. Now when I open it none of the options in
the left colume work. They are all faded and don't let you click on them.
Like "Check for Solutions". Any help would be gratful. Thanks, Randy
Old 07-09-2006   #2 (permalink)
Rasmus Bertelsen
Re: Problem Reports and Solutions
"Randy K." <RandyK@discussions.microsoft.com> wrote in message
news:EC22C064-9CD7-4E31-B9BA-14C5D1DFD15A@microsoft.com...
> in
Which Optimize program was that? I wasn't aware of any that was compatible
with Vista yet?
Regards,
Rasmus Bertelsen
Old 07-09-2006   #3 (permalink)
The program is another beta but it works good. Just start as an admin. and
click on the options to make your chooses. A screen will come up where you
have many options including Optimize. After it runs look at the issues it
finds carefully and uncheck any you don't want the program to optimize for
you. I learned the hard way. Once you get it tweeked the way you want it,
it's a really good program. Oh yea I guess you need the name or link :
www.iobit.com and the program name is ; Advanced WindowsCare V2 . I hope
it's what you need. Randy
> > in
> with Vista yet?
> Regards,
> Rasmus Bertelsen
Problem Reports and Solutions.....? Vista performance & maintenance
Problem Reports and Solutions Vista General
Problem Reports and Solutions KB Vista General
problem reports and solutions Vista General
