| | Enabling Fonts. Hi - I design Greeting Cards and went into American Greetings to see their Create and Print. When I go to personalize a card, an error message comes up (Unable to download "font"). Happens with all fonts. Scripting, etc. is enabled. Any ideas? I am using VISTA Home Premium - 32-Bit - 2GB RAM. louie |
| | RE: Enabling Fonts. Hello, Just wondering if you ever received a fix for this because I am experiencing the same problem? I am also unable to download the spell check library. I contacted American Greetings and they were unable to solve this. If you have any information please advise. Thanks "louie" wrote: Quote: > Hi - I design Greeting Cards and went into American Greetings to see their > Create and Print. When I go to personalize a card, an error message comes > up (Unable to download "font"). Happens with all fonts. Scripting, etc. > is enabled. Any ideas? I am using VISTA Home Premium - 32-Bit - 2GB RAM. > > louie > > |
| Vista Home Premium 32bit | Re: Enabling Fonts. Hello, I wrote American Greetings about this same problem, but I didn't get a response. Did you ever find a solution? If you have, I would be most appreciative if you would share it. Thanks jjl |
| | RE: Enabling Fonts. Hello, Here is how to fix the problem with downloading fonts and also the spell check. Hello, We are sorry that you are experiencing a problem with the Create and Print section of our site. Our technicians have been notified of this problem and are working to correct it. Thank you so much for your patience and for bringing this problem to our attention. Please follow these directions to allow our fonts to download: 1. Click the windows icon in the lower left corner of your screen. 2. Select the control panel option in this menu. 3. Select the user accounts option in this menu. 4. Select user accounts. 5. Select Turn User Account Control on or off 6. If prompted ?windows needs permission to continue? select continue. 7. Uncheck the option to user account control and then click ok. 8. From here you will be prompted to restart your computer. 9. Once you have restarted your computer please return to our website and select a card to print. Your fonts will download to your computer. Reverse these steps to re-activate your user controls after downloading fonts I hope this helps. If you have any further questions or concerns, please contact us again. BLH Quote: > |
| Enabling S.M.A.R.T | Software | |||
| Fonts - signature font lost in list of fonts | Vista mail | |||
| Enabling fonts. | Vista performance & maintenance | |||
| Enabling Fonts. | Vista performance & maintenance | |||
| Enabling fonts in Create and Print Software. | Vista performance & maintenance | |||
