Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - System Restore and disk defrag problems
Old 12-13-2007   #1 (permalink)
Frustrated Judy
1) This computer was new in August and is running Vista Ultimate.
2) Was having a problem with the disk defrag- it wouldn't pull up the dialog
to allow me to start the defrag manually- I got frustrated and downloaded a
freebe fromn Auslogics and it seemed to work fine.
3) later went to go online and could not access anything I had to sign into
such as banking, etc.
4) thinking it had to do with the Ausologics problem as I hadn't installed
anything else in a month or so I uninstalled the program and restarted the
computer. Still couldn't access anything
5) went to system restore- the last restore point was 12/3. When I attempted
to restore back to that date it wouldn't allow me to do so. The error was
"Local disk has errors. File System Corruption on Local Disk C. Check disk
errors before it can be resotred"
6) when I attempted to do that using the untility that it gave me it said it
was unable to check disk and to schedule for next time computer starts up.
So I turned off the system and let it sit a bit.
7) when I restarted it I got the message "cannot open volume for direct
access"
Now I'm way out of my league. Can anyone out there help me with this. I
really need to access my banking!
Old 12-13-2007   #2 (permalink)
Vista Ultimate x64
Re: System Restore and disk defrag problems
Diskeeper 2008 is by far the best defrag, as it does it for you when the computer is idle.
As far as the disk, can you get so far as to boot into safe mode with command prompt to run a check disk?
System Restore - disk space Tutorials
Defrag & System Restore Improvement Suggestions Vista performance & maintenance
Can't access disk defrag or system restore? Vista General
Disk Defrag problems Vista General
System restore and defrag General Discussion
