Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
ADVENT 7113 lock help!!!
Update your Vista Drivers Update Your Drivers Now!!
Closed Thread
Thread Tools Display Modes
Old 12-14-2007   #1 (permalink)
LISA
Guest
I HAVE A ADVENT 7113 AND LATELY WHEN I LEAVE IT FOR MORE THAN A FEW SECONDS
IT LOCKS AND I HAVE TO PUNCH IN MY PASSWORD TO UNLOCK IT.THIS IS REALLY
GETTING ON MY NERVES AS IT HAS ONLY JUST STARTED AND I KNOW I'VE CAUSED IT
BUT I DONT KNOW HOW TO STOP IT CAN ANYONE HELP!!!
Old 12-14-2007   #2 (permalink)
Dwarf
Guest
RE: ADVENT 7113 lock help!!!
Hi Lisa,
First of all, please do not post using all capitals. This is considered to
be shouting and, by some people, rude. Use capitals only to emphasise or
highlight something. Now to answer your query. Do you have an active
screensaver? If so, then try the following. Right-click anywhere on a blank
part of your desktop. In the menu that appears, select (left-click)
'Personalize'. Next, select 'Screen Saver' on the 'Personalize appearance and
sounds' screen that opens. Click to remove the tick next to 'On resume,
display logon screen'. Click 'OK' to save your changes and then close the
opened 'Personalize appearance and sounds' screen.
Dwarf
Old 01-26-2008   #3 (permalink)
Linnybins
Guest
Hi there, I noticed your comment on shouting, and though I agree, I fully
understand ADVENT's frustration. Perhaps you can help me with my problem too.
When I leave my PC idle for a few hours (sometimes I just close the lid at
night instead of shutting down) I find the appearance of my desktop becomes
magnified, the clock stretches out of shape, and the fonts look strange. If
I go ahead and use it, everything that comes up is also magnified. It's
disconcerting, so I always restart the computer and it works normally. By the
way I WISH I NEVER GOT VISTA! If I could turn back my elongated clock I
would stick with XP.
"Dwarf" wrote:
Quote:
> Hi Lisa,
> Dwarf
Old 01-27-2008   #4 (permalink)
Dwarf
Guest
Hi Linnybins,
First of all, please do not tack a question onto someone else's thread
unless the question is directly related to that already posted. Start a new
thread instead. That said, I'll endeavor to answer your query. To do so, I
need a bit more information from you. What is the make and model of your
laptop? What is the screen's native resolution? What resolution and colour
depth are you using when everything appears normal and what are those values
when the screen appears 'strange'? It sounds as though it could be a graphics
driver problem.
Dwarf
> "Dwarf" wrote:
Quote:
> > Hi Lisa,
> > Dwarf
Closed Thread
Display Modes
ADVENT 7113 NOT SHUTTING DOWN PROPERLY LISA Vista performance & maintenance 1 03-26-2008 07:45 PM
Toshiba Equium refusing to do System Restores & Advent query - help kplumm Vista General 4 03-26-2008 12:48 PM
Notification area/ How to get rid of Caps Lock, Scroll Lock Heidi Vista General 4 02-01-2008 08:14 PM
Advent Laptop 7111 How good for WIndows Vista Premium Edition? Download Help Vista General 5 03-03-2007 07:37 AM
DVD player not working Advent 7063m =?Utf-8?B?TWF0dA==?= Vista music pictures video 0 08-09-2006 10:46 AM
Update your Vista Drivers Update Your Vista Drivers Now!!
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
