| | Beeping Sound Hi Could any one suggest me solution of the problem that occured after opening a email in my junk folder. My computer processor is now starting with a beeping sound and the cursor to open any folder automatically set itself at the bottom folder. After one minute of start computer again works normally. I tried system restore but nothing happened. Thanks Merry Christmas -- Braham |
| | Re: Beeping Sound Hi there Thanks for sparing time. The beeping sound was before start of window. The problem was created by the scroll down button. I dont know how it got stuck and the cursor was scrolling all the folders automatically. Now I fixed it and everything is starting normally now. Braham "Brian" wrote: Quote: > > "BRAHAM" <jot@xxxxxx> wrote in message > news:24CD8E77-5480-47BE-952C-97A104AA5E89@xxxxxx Quote: > > Hi > > Could any one suggest me solution of the problem that occured after > > opening a email in my junk folder. My computer processor is now starting > > with a beeping sound and the cursor to open any folder automatically set > > itself at the bottom folder. After one minute of start computer again > > works > > normally. I tried system restore but nothing happened. > > > > Thanks > > Merry Christmas > > -- > > Braham > Braham, > > Beeps on machine startup but before Windows loads (or won't load) usually > indicates a problem or failure at the hardware system level. Such a problem > may or may not have been the result of opening an infected e-mail. > > Does your computer make a series of beeps when you turn it on but before > Windows starts? > > Does Windows start and run after the series of beeps? > > What antivirus and/or spyware protection are your using? Check your AV > program for events. Anything there? > > What is your motherboard brand and model? How many beeps do you hear? > > Brian > > > > > > |
| Beeping sound with administration login | Vista account administration | |||
| Vista is always beeping at me | Vista General | |||
| Internal Beeping | Vista performance & maintenance | |||
| constant beeping | Vista General | |||
| beeping sound | Vista music pictures video | |||
