Right now the checkbox for Power is grayed out while everything else is
checked and fine. I tried unchecking and checking the hide inactive icons and
also went into customize and restored everything to the default setting. I
also restarted the computer but it's still grayed out. Can you help me out?
"t.beakart@xxxxxx" wrote:
> Right click on the Start button, click "Properties". Where it says
> "Notification icon", click that tab. On the right click "customize"
> and there should be a list of icons with a button at the bottom that
> says "restore defaults". Click that that and save the changes. Now
> the power checkbox should work!
> Hope that helps. ~
