| | Control Panel / "Programs and Features" Won't Open When I click on the "Program and Features" icon in the Control Panel window, I get the response "Windows Explorer has stopped working", then "Windows is checking for a solution to the problem", then "Windows Explorer is restarting". This happens every time I click on "Programs and Features". Re-booting does not help. Has anyone else had this problem? Any ideas on how to correct this problem? Thanks very much. |
| | Re: Control Panel / "Programs and Features" Won't Open NumberCruncher, A post from Rick Rogers....... Quote: A fix would only be made available if it were broken for many people. For most explorer is not broken, however I have seen it broken by the addition of spy/ad programs, incompatible shell enhancing programs, and other software. You will need to selectively disable running programs to decipher which one is interfering with the shell on your system. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org End Quote: Also if you need to uninstall something without using Control Panel, may I suggest a program I use and is a standalone program which you do not need to install. MyUninstaller v1.37 MyUninstaller is an alternative utility to the standard Add/Remove applet of Windows operating system http://www.nirsoft.net/utils/index.html#desktop_utils -- All the best, SG "NumberCruncher" <NumberCruncher@xxxxxx> wrote in message news:ADF46F0B-F58B-49D0-A861-9D584FBF4393@xxxxxx Quote: > When I click on the "Program and Features" icon in the Control Panel > window, > I get the response "Windows Explorer has stopped working", then "Windows > is > checking for a solution to the problem", then "Windows Explorer is > restarting". This happens every time I click on "Programs and Features". > Re-booting does not help. Has anyone else had this problem? Any ideas on > how > to correct this problem? Thanks very much. > > |
| | Re: Control Panel / "Programs and Features" Won't Open Thanks SG. That is some very logical advice. "SG" wrote: Quote: > NumberCruncher, > > A post from Rick Rogers....... > > Quote: > A fix would only be made available if it were broken for many people. For > most explorer is not broken, however I have seen it broken by the addition > of spy/ad programs, incompatible shell enhancing programs, and other > software. You will need to selectively disable running programs to decipher > which one is interfering with the shell on your system. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > End Quote: > > Also if you need to uninstall something without using Control Panel, may I > suggest a program I use and is a standalone program which you do not need to > install. > > MyUninstaller v1.37 > MyUninstaller is an alternative utility to the standard Add/Remove applet of > Windows operating system > http://www.nirsoft.net/utils/index.html#desktop_utils > > -- > All the best, > SG > > "NumberCruncher" <NumberCruncher@xxxxxx> wrote in message > news:ADF46F0B-F58B-49D0-A861-9D584FBF4393@xxxxxx Quote: > > When I click on the "Program and Features" icon in the Control Panel > > window, > > I get the response "Windows Explorer has stopped working", then "Windows > > is > > checking for a solution to the problem", then "Windows Explorer is > > restarting". This happens every time I click on "Programs and Features". > > Re-booting does not help. Has anyone else had this problem? Any ideas on > > how > > to correct this problem? Thanks very much. > > > > > |
| "Add or remove programs" not visible in Control Panel | Vista General | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| Control Panel / Program and Features / "UNINSTALL" | Vista General | |||
| Control Panel open causes "Windows Explorer has stopped working".... | Vista General | |||
| Missing Data - Control Panel\Programs and Features | Vista General | |||
