Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - please help its driving me insane
Old 01-20-2008   #1 (permalink)
Vista Basic 32bit.
i used advanced vista optimiser to give my laptop a good clean out as i do every week. but this time when i went to log on the diagnostic comes and says either change proxy settings or try resetting local connection setting. i tried resetting many a time which as done no good. web address bar states where its going but the diag box comes on again.so in the mean time while this is all going on a new tab keeps on opening by its self and saying the same thing,this started to happen before i cleaned my l.p but it was just redirecting to a blank page. that is why i did the clean.anyhow resetting the lan did not work so i reset the internet expolorer in the tools on the bar. which as worked but the same thing is still happening with the tab ,but now its redirecting to all the freebiee sites and it will not stop. i have spyware-adware-trojan software on my l.p and still no good it did pick up 3 infections which it sorted out, its driving me f*&^%*ng nuts please help
Last edited by djchina74; 01-20-2008 at 08:08 PM.. Reason: ran yahoo antispy program
Old 01-20-2008   #2 (permalink)
Vista Basic 32bit.
Re: please help its driving me insane
three warnings flashed up when running this program:- u torrant =trojan, CWS.Searchmeup= hijacker, ISTBAR= HIJACKER. PLEASE INFORM me if these are the ones because i have the web address fo all of them.
Old 01-20-2008   #3 (permalink)
Rick Rogers
I have no idea what "advanced vista optimiser" is, but I would see if it has
an "undo" function to fix the damage its done. Sounds like some malware has
taken over the system.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"djchina74" <djchina74.33ifs1@xxxxxx-mx.forums.net> wrote in message
news:djchina74.33ifs1@xxxxxx-mx.forums.net...
> djchina74
Old 01-20-2008   #4 (permalink)
Mike Hall - MVP
"Rick Rogers" <rick@xxxxxx> wrote in message
news:%23iEY9x8WIHA.4808@xxxxxx
Quote:
> Hi,
> has an "undo" function to fix the damage its done. Sounds like some
> malware has taken over the system.
> Best of Luck,
>> djchina74
Rick
This perhaps..
http://www.advancedvistaoptimizer.co...FQh3MAodpRgdqg
No contact info, land mail address, nothing. Just a bunch of claims..
Mike Hall - MVP
http://msmvps.com/blogs/mikehall/default.aspx
Old 01-20-2008   #5 (permalink)
Rick Rogers
Yeah, that's sort of scary.
Best of Luck,
"Mike Hall - MVP" <mikehall@xxxxxx> wrote in message
news:etu9zH9WIHA.1208@xxxxxx
Quote:
>> Hi,
>> Best of Luck,
>>> djchina74
> Rick
> This perhaps..
> Mike Hall - MVP
Old 01-20-2008   #6 (permalink)
Mike Hall - MVP
"djchina74" <djchina74.33ihv0@xxxxxx-mx.forums.net> wrote in message
news:djchina74.33ihv0@xxxxxx-mx.forums.net...
> djchina74
Dj
I have a feeling that your 'optimizer' is the malware.
Go to this web site, bookmark it and then use the e-mail contact link to
Mark Hastings, the author of the web site. In the e-mail, explain exactly
what has happened and supply the link for 'Advanced Vista Optimizer'..
http://www.pchell.com/
Mike Hall - MVP
Old 01-21-2008   #7 (permalink)
Vista Basic 32bit.
Hi ,Rick and Mike further to this saga of mine, the programme in question is Advanced Vista Optimizer 2008 and from there web site selling point it is supported by microsoft. I would be happy to say the problem was recified this morning, but as i log on, windows problem box flashed up saying it can,t connect due to it can,t find any D.N.S. After having a look round my network connections they had all been turned off and messed about with. Basically i could not log on but the incoming connection was still active if you get what i mean.For now the emergancy is over, for now cheers both for all your input.Will keep you updated.
Old 01-21-2008   #8 (permalink)
Mike Hall - MVP
"djchina74" <djchina74.33j5kr@xxxxxx-mx.forums.net> wrote in message
news:djchina74.33j5kr@xxxxxx-mx.forums.net...
> djchina74
DJ
Anybody can copy the Microsoft Certified Gold Partner logo onto their
website.
Stay away from any program which promises to fix all ills. They never work
the way that the promises suggest..
Mike Hall - MVP
Old 01-21-2008   #9 (permalink)
Vista home Premium x64
i know this aint anything what your thinking of but if you wanna optimize vista a bit try using registry mechanic with a crack code but keep that code just incase it trys to update
hp laptop Vista 32bit is driving me insane!!! Sound & Audio
Asus sata dvdrw driving me insane Vista hardware & devices
Driving me insane Vista networking & sharing
This is driving me insane / BSOD General Discussion
Vista disk activity driving me insane Vista General
