| | Help understanding Vista Home Basic and Hard Drive reccognition? I have win Vista Home basic installed on the same computer twice. One is running on a scsi drive with two partitions and the other is running on an sata drive. Both op systems are bootable using vista boot pro. Problem I am having is the op system installed on the scsi drive does not reccognize the sata drive which has two partition on it. One being the op system and the other for backup and both are primary partitions. When I boot from sata drive i can see all partitions on both drives. Why is this so if anyone has any thoughts on this I would be delighted to be able to access all partitions on both drives frome either or? Thanks for any input that would help me resolve this conflict or whatever you can call it.(problem) |
| USB jump drive on Vista Home Basic won't work | Vista hardware & devices | |||
| lost hard disc memorary after upgrading to Vista home basic | Vista General | |||
| VISTA HOME PREMIUM HARD DRIVE | Vista hardware & devices | |||
| Data Hard disk not reflected after installing Viats Home Basic | Vista installation & setup | |||
| Vista Home Basic map network drive | Vista networking & sharing | |||
