| | CD ROM / Registry problems Hi, I am running Vista on a Gateway laptop. I have Norton 360 for my antivirus (wouldn't recommend it). The problem is that about once a week when I go to use the cd rom I get the error 10 message saying it can't find the device. I have to go in to the registry and edit it to remove "upper filters", whatever that is. As soon as I do that and reboot it's fine for a week or so. Why does the upper filter item keep reappearing and how can I stop it. Any ideas? Thanks, Rick |
| | Re: CD ROM / Registry problems I'd remove the Norton software and see if the problem goes away. The problem with that entry is from the use of a third party driver file for the optical drive. Either it gets rewritten by the software, or it's getting detected as missing and being replaced. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Rick03860" <Rick03860@xxxxxx> wrote in message news:0DD86066-5D20-47A5-B62F-CAA593C79592@xxxxxx Quote: > Hi, > I am running Vista on a Gateway laptop. I have Norton 360 for my antivirus > (wouldn't recommend it). The problem is that about once a week when I go > to > use the cd rom I get the error 10 message saying it can't find the device. > I > have to go in to the registry and edit it to remove "upper filters", > whatever > that is. As soon as I do that and reboot it's fine for a week or so. Why > does the upper filter item keep reappearing and how can I stop it. Any > ideas? > Thanks, Rick |
| Windows registry problems | General Discussion | |||
| Registry problems | Vista General | |||
| Modding Registry Problems | PowerShell | |||
| Registry Problems | Vista General | |||
| registry problems in RC2.... | Vista installation & setup | |||
